[gdal-dev] GetGeoTransform returning different values
Even Rouault
even.rouault at spatialys.com
Fri Sep 5 14:24:27 PDT 2025
> From what I can see, they seem to be kind of far apart to be just
> significant digits. It’s calculating different pixel sizes and
> rotations which in turn is causing the lat/lon conversion to be off.
> The only other thing I can think of is that I compiled the API with
> PDFium and I believe the homebrew install uses Poppler.
Ah yes that might be it. Such differences ring a bell. I never dig up
completely to figure out but I presume that one of the backend must just
use 32-bit floats at some points whereas the other one 64 bit floats.
