[gdal-dev] Fail to get tiles from COG hosted in minio and served by a cogserver
Luigi Pirelli
luipir at gmail.com
Wed Sep 10 04:11:52 PDT 2025
Hi gdal comunity
I'm asking help to understand some problems serving COG files via a custom
COG server that hide the access to the files stored in an object store as
Minio.
the file is here:
https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
below the detailed log if accessing tiles and coping using gdal_translate.
Server in the middle seems serving all partial request correctly without
any warning about mismatch respect bytes requested and served, but in any
case the copy ends with a bunch of
*CPLError: Request for 220606604-223374076 failed with response_code=206*
errors.
adding more strange behaviour i can see that this rasterio code:
import rasterio
import os
os.environ["CPL_DEBUG"] = "ON"
cog_url="
with rasterio.open(cog_url) as dataset:
block_width, block_height = dataset.block_shapes[0] # Block size (tile
dimensions in pixels)
width = dataset.width
height = dataset.height
a_tile_window = rasterio.windows.Window(
col_off=width //2 , row_off=height //2, width=block_width-31,
height=block_height-31
a_tile = dataset.read(1, window=a_tile_window)
Give error if window is *block_width-31*, but not error if getting a
*block_width-32* size
any hint or help is appreciated
thank you
Luigi Pirelli
GDAL_TRANSLATE LOG
*12:52 $ gdal_translate
/vsicurl/https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
<https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif>
~/Downloads/out.tifCPL: Loading configuration from
/home/ginetto/.gdal/gdalrcCPL: Ignoring configuration option CPL_DEBUG=OFF
from configuration file as it is already set as an environment variableCPL:
Ignoring configuration option CPL_LOG_ERRORS=OFF from configuration file as
it is already set as an environment variableHTTP: libcurl/8.5.0
OpenSSL/3.0.13 zlib/1.3 brotli/1.1.0 zstd/1.5.5 libidn2/2.3.7 libpsl/0.21.2
(+libidn2/2.3.7) libssh/0.10.6/openssl/zlib nghttp2/1.59.0 librtmp/2.3
OpenLDAP/2.6.7CURL_INFO_TEXT: Host
geoportale-nhw-preprod.comune.roma.it:443
<http://geoportale-nhw-preprod.comune.roma.it:443> was
resolved.CURL_INFO_TEXT: IPv6: (none)CURL_INFO_TEXT: IPv4:
93.63.254.107CURL_INFO_TEXT: Trying 93.63.254.107:443...CURL_INFO_TEXT:
Connected to geoportale-nhw-preprod.comune.roma.it
<http://geoportale-nhw-preprod.comune.roma.it> (93.63.254.107) port
443CURL_INFO_TEXT: ALPN: curl offers h2,http/1.1CURL_INFO_TEXT: TLSv1.3
(OUT), TLS handshake, Client hello (1):CURL_INFO_TEXT: CAfile:
/etc/ssl/certs/ca-certificates.crtCURL_INFO_TEXT: CApath:
/etc/ssl/certsCURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Server hello
(2):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Encrypted Extensions
(8):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Certificate
(11):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, CERT verify
(15):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Finished
(20):CURL_INFO_TEXT: TLSv1.3 (OUT), TLS change cipher, Change cipher spec
(1):CURL_INFO_TEXT: TLSv1.3 (OUT), TLS handshake, Finished
(20):CURL_INFO_TEXT: SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
/ X25519 / RSASSA-PSSCURL_INFO_TEXT: ALPN: server accepted
http/1.1CURL_INFO_TEXT: Server certificate:CURL_INFO_TEXT: subject: C=IT;
ST=Lazio; L=Roma; O=Roma Capitale; CN=*.comune.roma.it
<http://comune.roma.it>CURL_INFO_TEXT: start date: Dec 20 00:00:00 2024
GMTCURL_INFO_TEXT: expire date: Jan 7 23:59:59 2026 GMTCURL_INFO_TEXT:
subjectAltName: host "geoportale-nhw-preprod.comune.roma.it
<http://geoportale-nhw-preprod.comune.roma.it>" matched cert's
"*.comune.roma.it <http://comune.roma.it>"CURL_INFO_TEXT: issuer: C=US;
O=DigiCert Inc; OU=www.digicert.com <http://www.digicert.com>; CN=GeoTrust
TLS RSA CA G1CURL_INFO_TEXT: SSL certificate verify ok.CURL_INFO_TEXT:
Certificate level 0: Public key type RSA (2048/112 Bits/secBits), signed
using sha256WithRSAEncryptionCURL_INFO_TEXT: Certificate level 1: Public
key type RSA (2048/112 Bits/secBits), signed using
sha256WithRSAEncryptionCURL_INFO_TEXT: Certificate level 2: Public key
sha256WithRSAEncryptionCURL_INFO_TEXT: using HTTP/1.xCURL_INFO_TEXT: Server
auth using Basic with user 'anonymous'CURL_INFO_HEADER_OUT: HEAD
HTTP/1.1Host: geoportale-nhw-preprod.comune.roma.it
<http://geoportale-nhw-preprod.comune.roma.it>Authorization: Basic
YW5vbnltb3VzOg==User-Agent: GDAL/3.8.4Accept: */*CURL_INFO_TEXT: TLSv1.3
(IN), TLS handshake, Newsession Ticket (4):CURL_INFO_TEXT: TLSv1.3 (IN),
TLS handshake, Newsession Ticket (4):CURL_INFO_TEXT: old SSL session ID is
stale, removingCURL_INFO_HEADER_IN: HTTP/1.1 200 OKCURL_INFO_HEADER_IN:
Date: Wed, 10 Sep 2025 10:52:38 GMTCURL_INFO_HEADER_IN: Server:
ApacheCURL_INFO_HEADER_IN: Content-Length: 810434714CURL_INFO_HEADER_IN:
last-modified: 2025-07-17 16:23:21+00:00CURL_INFO_HEADER_IN: etag:
"a3b9bd1ae8c52585692c2bff1eda0171"CURL_INFO_HEADER_IN: Set-Cookie:
cookiesession2=63360d725398f949eeddf1157658c168;max-age=3600;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
Set-Cookie: cookiesession1=678B287018D2B682BD6915142E5A0D14;Expires=Thu, 10
Sep 2026 10:52:38 GMT;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
Strict-Transport-Security: max-age=31536000CURL_INFO_HEADER_IN:
CURL_INFO_TEXT: Connection #0 to host geoportale-nhw-preprod.comune.roma.it
<http://geoportale-nhw-preprod.comune.roma.it> left intactVSICURL:
GetFileSize(https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif)=810434714
<https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif)=810434714>
response_code=200VSICURL: Downloading 0-16383
(https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif).
<https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif).>..CURL_INFO_TEXT:
Found bundle for host: 0x59cab0e97790 [serially]CURL_INFO_TEXT: Can not
multiplex, even if we wanted toCURL_INFO_TEXT: Re-using existing connection
with host geoportale-nhw-preprod.comune.roma.it
<http://geoportale-nhw-preprod.comune.roma.it>CURL_INFO_TEXT: Server auth
using Basic with user 'anonymous'CURL_INFO_HEADER_OUT: GET
YW5vbnltb3VzOg==User-Agent: GDAL/3.8.4Accept: */*Range:
bytes=0-16383CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial
ContentCURL_INFO_HEADER_IN: Date: Wed, 10 Sep 2025 10:52:38
GMTCURL_INFO_HEADER_IN: Server: ApacheCURL_INFO_HEADER_IN: Content-Type:
image/tiff; application=geotiff;
profile=cloud-optimizedCURL_INFO_HEADER_IN: Content-Length:
16383CURL_INFO_HEADER_IN: content-range: bytes=0-16383CURL_INFO_HEADER_IN:
accept-ranges: bytesCURL_INFO_HEADER_IN: Set-Cookie:
<http://geoportale-nhw-preprod.comune.roma.it> left intactVSICURL: Got
response_code=206GDAL:
GDALOpen(/vsicurl/https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
<https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif>,
this=0x59cab0e90a10) succeeds as GTiff.GDAL: Using GTiff driverInput file
size is 20544, 14016GDAL: Using GTiff driverGTiff:
ScanDirectories()VSICURL: Downloading 16384-49151
bytes=16384-49151CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial
32767CURL_INFO_HEADER_IN: content-range:
bytes=16384-49151CURL_INFO_HEADER_IN: accept-ranges:
response_code=206GTiff: Opened 10272x7008 overview.GTiff: Opened 5136x3504
overview.GTiff: Opened 2568x1752 overview.GTiff: Opened 1284x876
overview.GTiff: Opened 642x438 overview.0GDAL: GDAL_CACHEMAX = 4716 MBGDAL:
GDALDatasetCopyWholeRaster(): 20544*512 swaths, bInterleave=1VSICURL:
Downloading 220606604-223374076
<https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif).>..VSICURL:
Downloading 223374078-226365702
Downloading 226365704-226856674
Downloading 226856676-228483196
Downloading 228483198-229596738
Downloading 229596740-230773941
bytes=220606604-223374076CURL_INFO_TEXT: Found bundle for host:
0x59cab0e97790 [serially]CURL_INFO_TEXT: Can not multiplex, even if we
wanted toCURL_INFO_TEXT: Hostname geoportale-nhw-preprod.comune.roma.it
<http://geoportale-nhw-preprod.comune.roma.it> was found in DNS
cacheCURL_INFO_TEXT: Trying 93.63.254.107:443...CURL_INFO_TEXT: Found
multiplex, even if we wanted toCURL_INFO_TEXT: Hostname
cacheCURL_INFO_TEXT: Trying 93.63.254.107:443...CURL_INFO_TEXT: Connected
/etc/ssl/certsCURL_INFO_TEXT: Connected to
/etc/ssl/certsCURL_INFO_HEADER_IN: HTTP/1.1 206 Partial
2767472CURL_INFO_HEADER_IN: content-range:
bytes=220606604-223374076CURL_INFO_HEADER_IN: accept-ranges:
CURL_INFO_TEXT: Connected to geoportale-nhw-preprod.comune.roma.it
auth using Basic with user 'anonymous'CURL_INFO_HEADER_OUT: GET
bytes=226856676-228483196CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
Server hello (2):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Encrypted
Extensions (8):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Certificate
bytes=228483198-229596738CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
bytes=229596740-230773941CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
bytes=223374078-226365702CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
bytes=226365704-226856674CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
Newsession Ticket (4):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
Newsession Ticket (4):CURL_INFO_TEXT: old SSL session ID is stale,
removingCURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Newsession Ticket
(4):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Newsession Ticket
(4):CURL_INFO_TEXT: old SSL session ID is stale, removingCURL_INFO_TEXT:
TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):CURL_INFO_TEXT: old SSL
session ID is stale, removingCURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
removingCURL_INFO_HEADER_IN: HTTP/1.1 206 Partial
1626520CURL_INFO_HEADER_IN: content-range:
bytes=226856676-228483196CURL_INFO_HEADER_IN: accept-ranges:
cookiesession2=d17e9524a2e2bd46eeddf1157658c168;max-age=3600;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
Set-Cookie: cookiesession1=678B28700CB3ACBDE48CB06AABF53369;Expires=Thu, 10
CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial ContentCURL_INFO_HEADER_IN: Date:
ApacheCURL_INFO_HEADER_IN: Content-Type: image/tiff; application=geotiff;
1113540CURL_INFO_HEADER_IN: content-range:
bytes=228483198-229596738CURL_INFO_HEADER_IN: accept-ranges:
Set-Cookie: cookiesession1=678B28701369CC6FF14EFC0F7C49DEE6;Expires=Thu, 10
Wed, 10 Sep 2025 10:52:39 GMTCURL_INFO_HEADER_IN: Server:
2991624CURL_INFO_HEADER_IN: content-range:
bytes=223374078-226365702CURL_INFO_HEADER_IN: accept-ranges:
cookiesession2=d17e9524a2e2bd46eeddf1157758c168;max-age=3600;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
Set-Cookie: cookiesession1=678B28708EB2D0D778D6A3C28D0B2FE0;Expires=Thu, 10
Sep 2026 10:52:39 GMT;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
490970CURL_INFO_HEADER_IN: content-range:
bytes=226365704-226856674CURL_INFO_HEADER_IN: accept-ranges:
cookiesession2=63360d725398f949eeddf1157758c168;max-age=3600;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
Set-Cookie: cookiesession1=678B28708E661F83CF8066E206817AAA;Expires=Thu, 10
1177201CURL_INFO_HEADER_IN: content-range:
bytes=229596740-230773941CURL_INFO_HEADER_IN: accept-ranges:
Set-Cookie: cookiesession1=678B287076DD1049BDA4DB2C6294E06F;Expires=Thu, 10
CURL_INFO_TEXT: Connection #4 to host geoportale-nhw-preprod.comune.roma.it
<http://geoportale-nhw-preprod.comune.roma.it> left intactCURL_INFO_TEXT:
Connection #2 to host geoportale-nhw-preprod.comune.roma.it
Connection #5 to host geoportale-nhw-preprod.comune.roma.it
Connection #3 to host geoportale-nhw-preprod.comune.roma.it
Connection #1 to host geoportale-nhw-preprod.comune.roma.it
<http://geoportale-nhw-preprod.comune.roma.it> left intactCPLError: Request
for 220606604-223374076 failed with response_code=206ERROR 1: Request for
220606604-223374076 failed with response_code=206CPLError: Request for
223374078-226365702 failed with response_code=206ERROR 1: Request for
223374078-226365702 failed with response_code=206CPLError: Request for
226365704-226856674 failed with response_code=206ERROR 1: Request for
226365704-226856674 failed with response_code=206CPLError: Request for
226856676-228483196 failed with response_code=206ERROR 1: Request for
226856676-228483196 failed with response_code=206CPLError: Request for
228483198-229596738 failed with response_code=206ERROR 1: Request for
228483198-229596738 failed with response_code=206CPLError: Request for
229596740-230773941 failed with response_code=206ERROR 1: Request for
229596740-230773941 failed with response_code=206VSICURL: Download
completedVSICURL: Downloading 220594176-221118463
bytes=220594176-221118463CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial
ContentCURL_INFO_HEADER_IN: Date: Wed, 10 Sep 2025 10:52:40
524287CURL_INFO_HEADER_IN: content-range:
bytes=220594176-221118463CURL_INFO_HEADER_IN: accept-ranges:
cookiesession2=63360d725398f949eeddf1157858c168;max-age=3600;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
CURL_INFO_TEXT: Connection cache is full, closing the oldest
oneCURL_INFO_TEXT: Connection #0 to host
response_code=206CPLError: TIFFFillTile:Read error at row 0, col 0, tile 1;
got 15683 bytes, expected 580846ERROR 1: TIFFFillTile:Read error at row 0,
col 0, tile 1; got 15683 bytes, expected 580846CPLError:
TIFFReadEncodedTile() failed.ERROR 1: TIFFReadEncodedTile()
failed.CPLError:
band 1: IReadBlock failed at X offset 1, Y offset 0: TIFFReadEncodedTile()
failed.ERROR 1:
failed.GDAL:
GDALClose(/vsicurl/https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
this=0x59cab0e90a10)GDAL: In GDALDestroy - unloading GDAL shared library.*
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Book: Mastering QGIS3 - 3rd Edition
<https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250910/87925e4c/attachment-0001.htm>
