[gdal-dev] Fail to get tiles from COG hosted in minio and served by a cogserver
Luigi Pirelli luipir at gmail.com
Fri Sep 12 02:48:21 PDT 2025
Even, or someone else was able to replicate the error locally and was able
to discover something that I'm not able to view?
regards
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Book: Mastering QGIS3 - 3rd Edition
<https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
On Wed, 10 Sept 2025 at 13:11, Luigi Pirelli <luipir at gmail.com> wrote:
> Hi gdal comunity
> I'm asking help to understand some problems serving COG files via a custom
> COG server that hide the access to the files stored in an object store as
> Minio.
> the file is here:
> https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
> below the detailed log if accessing tiles and coping using gdal_translate.
> Server in the middle seems serving all partial request correctly without
> any warning about mismatch respect bytes requested and served, but in any
> case the copy ends with a bunch of
> *CPLError: Request for 220606604-223374076 failed with response_code=206*
> errors.
> adding more strange behaviour i can see that this rasterio code:
> import rasterio
> import os
> os.environ["CPL_DEBUG"] = "ON"
> cog_url="
> with rasterio.open(cog_url) as dataset:
>     block_width, block_height = dataset.block_shapes[0]  # Block size
> (tile dimensions in pixels)
>     width = dataset.width
>     height = dataset.height
>     a_tile_window = rasterio.windows.Window(
>         col_off=width //2 , row_off=height //2, width=block_width-31,
> height=block_height-31
>     a_tile = dataset.read(1, window=a_tile_window)
> Give error if window is *block_width-31*, but not error if getting a
> *block_width-32* size
> any hint or help is appreciated
> thank you
> Luigi Pirelli
> GDAL_TRANSLATE LOG
> *12:52 $ gdal_translate
> /vsicurl/https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
> <https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif>
> ~/Downloads/out.tifCPL: Loading configuration from
> /home/ginetto/.gdal/gdalrcCPL: Ignoring configuration option CPL_DEBUG=OFF
> from configuration file as it is already set as an environment variableCPL:
> Ignoring configuration option CPL_LOG_ERRORS=OFF from configuration file as
> it is already set as an environment variableHTTP: libcurl/8.5.0
> OpenSSL/3.0.13 zlib/1.3 brotli/1.1.0 zstd/1.5.5 libidn2/2.3.7 libpsl/0.21.2
> (+libidn2/2.3.7) libssh/0.10.6/openssl/zlib nghttp2/1.59.0 librtmp/2.3
> OpenLDAP/2.6.7CURL_INFO_TEXT: Host
> geoportale-nhw-preprod.comune.roma.it:443
> <http://geoportale-nhw-preprod.comune.roma.it:443> was
> resolved.CURL_INFO_TEXT: IPv6: (none)CURL_INFO_TEXT: IPv4:
> 93.63.254.107CURL_INFO_TEXT:   Trying 93.63.254.107:443...CURL_INFO_TEXT:
> Connected to geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it> (93.63.254.107) port
> 443CURL_INFO_TEXT: ALPN: curl offers h2,http/1.1CURL_INFO_TEXT: TLSv1.3
> (OUT), TLS handshake, Client hello (1):CURL_INFO_TEXT:  CAfile:
> /etc/ssl/certs/ca-certificates.crtCURL_INFO_TEXT:  CApath:
> /etc/ssl/certsCURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Server hello
> (2):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Encrypted Extensions
> (8):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Certificate
> (11):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, CERT verify
> (15):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Finished
> (20):CURL_INFO_TEXT: TLSv1.3 (OUT), TLS change cipher, Change cipher spec
> (1):CURL_INFO_TEXT: TLSv1.3 (OUT), TLS handshake, Finished
> (20):CURL_INFO_TEXT: SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
> / X25519 / RSASSA-PSSCURL_INFO_TEXT: ALPN: server accepted
> http/1.1CURL_INFO_TEXT: Server certificate:CURL_INFO_TEXT:  subject: C=IT;
> ST=Lazio; L=Roma; O=Roma Capitale; CN=*.comune.roma.it
> <http://comune.roma.it>CURL_INFO_TEXT:  start date: Dec 20 00:00:00 2024
> GMTCURL_INFO_TEXT:  expire date: Jan  7 23:59:59 2026 GMTCURL_INFO_TEXT:
>  subjectAltName: host "geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it>" matched cert's
> "*.comune.roma.it <http://comune.roma.it>"CURL_INFO_TEXT:  issuer: C=US;
> O=DigiCert Inc; OU=www.digicert.com <http://www.digicert.com>; CN=GeoTrust
> TLS RSA CA G1CURL_INFO_TEXT:  SSL certificate verify ok.CURL_INFO_TEXT:
> Certificate level 0: Public key type RSA (2048/112 Bits/secBits), signed
> using sha256WithRSAEncryptionCURL_INFO_TEXT:   Certificate level 1: Public
> key type RSA (2048/112 Bits/secBits), signed using
> sha256WithRSAEncryptionCURL_INFO_TEXT:   Certificate level 2: Public key
> sha256WithRSAEncryptionCURL_INFO_TEXT: using HTTP/1.xCURL_INFO_TEXT: Server
> auth using Basic with user 'anonymous'CURL_INFO_HEADER_OUT: HEAD
> HTTP/1.1Host: geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it>Authorization: Basic
> YW5vbnltb3VzOg==User-Agent: GDAL/3.8.4Accept: */*CURL_INFO_TEXT: TLSv1.3
> (IN), TLS handshake, Newsession Ticket (4):CURL_INFO_TEXT: TLSv1.3 (IN),
> TLS handshake, Newsession Ticket (4):CURL_INFO_TEXT: old SSL session ID is
> stale, removingCURL_INFO_HEADER_IN: HTTP/1.1 200 OKCURL_INFO_HEADER_IN:
> Date: Wed, 10 Sep 2025 10:52:38 GMTCURL_INFO_HEADER_IN: Server:
> ApacheCURL_INFO_HEADER_IN: Content-Length: 810434714CURL_INFO_HEADER_IN:
> last-modified: 2025-07-17 16:23:21+00:00CURL_INFO_HEADER_IN: etag:
> "a3b9bd1ae8c52585692c2bff1eda0171"CURL_INFO_HEADER_IN: Set-Cookie:
> cookiesession2=63360d725398f949eeddf1157658c168;max-age=3600;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
> Set-Cookie: cookiesession1=678B287018D2B682BD6915142E5A0D14;Expires=Thu, 10
> Sep 2026 10:52:38 GMT;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
> Strict-Transport-Security: max-age=31536000CURL_INFO_HEADER_IN:
> CURL_INFO_TEXT: Connection #0 to host geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it> left intactVSICURL:
> GetFileSize(https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif)=810434714
> <https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif)=810434714>
>  response_code=200VSICURL: Downloading 0-16383
> (https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif).
> <https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif).>..CURL_INFO_TEXT:
> Found bundle for host: 0x59cab0e97790 [serially]CURL_INFO_TEXT: Can not
> multiplex, even if we wanted toCURL_INFO_TEXT: Re-using existing connection
> with host geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it>CURL_INFO_TEXT: Server auth
> using Basic with user 'anonymous'CURL_INFO_HEADER_OUT: GET
> YW5vbnltb3VzOg==User-Agent: GDAL/3.8.4Accept: */*Range:
> bytes=0-16383CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial
> ContentCURL_INFO_HEADER_IN: Date: Wed, 10 Sep 2025 10:52:38
> GMTCURL_INFO_HEADER_IN: Server: ApacheCURL_INFO_HEADER_IN: Content-Type:
> image/tiff; application=geotiff;
> profile=cloud-optimizedCURL_INFO_HEADER_IN: Content-Length:
> 16383CURL_INFO_HEADER_IN: content-range: bytes=0-16383CURL_INFO_HEADER_IN:
> accept-ranges: bytesCURL_INFO_HEADER_IN: Set-Cookie:
> <http://geoportale-nhw-preprod.comune.roma.it> left intactVSICURL: Got
> response_code=206GDAL:
> GDALOpen(/vsicurl/https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
> <https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif>,
> this=0x59cab0e90a10) succeeds as GTiff.GDAL: Using GTiff driverInput file
> size is 20544, 14016GDAL: Using GTiff driverGTiff:
> ScanDirectories()VSICURL: Downloading 16384-49151
> bytes=16384-49151CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial
> 32767CURL_INFO_HEADER_IN: content-range:
> bytes=16384-49151CURL_INFO_HEADER_IN: accept-ranges:
> response_code=206GTiff: Opened 10272x7008 overview.GTiff: Opened 5136x3504
> overview.GTiff: Opened 2568x1752 overview.GTiff: Opened 1284x876
> overview.GTiff: Opened 642x438 overview.0GDAL: GDAL_CACHEMAX = 4716 MBGDAL:
> GDALDatasetCopyWholeRaster(): 20544*512 swaths, bInterleave=1VSICURL:
> Downloading 220606604-223374076
> <https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif).>..VSICURL:
> Downloading 223374078-226365702
> Downloading 226365704-226856674
> Downloading 226856676-228483196
> Downloading 228483198-229596738
> Downloading 229596740-230773941
> bytes=220606604-223374076CURL_INFO_TEXT: Found bundle for host:
> 0x59cab0e97790 [serially]CURL_INFO_TEXT: Can not multiplex, even if we
> wanted toCURL_INFO_TEXT: Hostname geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it> was found in DNS
> cacheCURL_INFO_TEXT:   Trying 93.63.254.107:443...CURL_INFO_TEXT: Found
> multiplex, even if we wanted toCURL_INFO_TEXT: Hostname
> cacheCURL_INFO_TEXT:   Trying 93.63.254.107:443...CURL_INFO_TEXT: Connected
> /etc/ssl/certsCURL_INFO_TEXT: Connected to
> /etc/ssl/certsCURL_INFO_HEADER_IN: HTTP/1.1 206 Partial
> 2767472CURL_INFO_HEADER_IN: content-range:
> bytes=220606604-223374076CURL_INFO_HEADER_IN: accept-ranges:
> CURL_INFO_TEXT: Connected to geoportale-nhw-preprod.comune.roma.it
> auth using Basic with user 'anonymous'CURL_INFO_HEADER_OUT: GET
> bytes=226856676-228483196CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> Server hello (2):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Encrypted
> Extensions (8):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Certificate
> bytes=228483198-229596738CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> bytes=229596740-230773941CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> bytes=223374078-226365702CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> bytes=226365704-226856674CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> Newsession Ticket (4):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> Newsession Ticket (4):CURL_INFO_TEXT: old SSL session ID is stale,
> removingCURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Newsession Ticket
> (4):CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Newsession Ticket
> (4):CURL_INFO_TEXT: old SSL session ID is stale, removingCURL_INFO_TEXT:
> TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):CURL_INFO_TEXT: old SSL
> session ID is stale, removingCURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> removingCURL_INFO_HEADER_IN: HTTP/1.1 206 Partial
> 1626520CURL_INFO_HEADER_IN: content-range:
> bytes=226856676-228483196CURL_INFO_HEADER_IN: accept-ranges:
> cookiesession2=d17e9524a2e2bd46eeddf1157658c168;max-age=3600;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
> Set-Cookie: cookiesession1=678B28700CB3ACBDE48CB06AABF53369;Expires=Thu, 10
> CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial ContentCURL_INFO_HEADER_IN: Date:
> ApacheCURL_INFO_HEADER_IN: Content-Type: image/tiff; application=geotiff;
> 1113540CURL_INFO_HEADER_IN: content-range:
> bytes=228483198-229596738CURL_INFO_HEADER_IN: accept-ranges:
> Set-Cookie: cookiesession1=678B28701369CC6FF14EFC0F7C49DEE6;Expires=Thu, 10
> Wed, 10 Sep 2025 10:52:39 GMTCURL_INFO_HEADER_IN: Server:
> 2991624CURL_INFO_HEADER_IN: content-range:
> bytes=223374078-226365702CURL_INFO_HEADER_IN: accept-ranges:
> cookiesession2=d17e9524a2e2bd46eeddf1157758c168;max-age=3600;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
> Set-Cookie: cookiesession1=678B28708EB2D0D778D6A3C28D0B2FE0;Expires=Thu, 10
> Sep 2026 10:52:39 GMT;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
> 490970CURL_INFO_HEADER_IN: content-range:
> bytes=226365704-226856674CURL_INFO_HEADER_IN: accept-ranges:
> cookiesession2=63360d725398f949eeddf1157758c168;max-age=3600;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
> Set-Cookie: cookiesession1=678B28708E661F83CF8066E206817AAA;Expires=Thu, 10
> 1177201CURL_INFO_HEADER_IN: content-range:
> bytes=229596740-230773941CURL_INFO_HEADER_IN: accept-ranges:
> Set-Cookie: cookiesession1=678B287076DD1049BDA4DB2C6294E06F;Expires=Thu, 10
> CURL_INFO_TEXT: Connection #4 to host geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it> left intactCURL_INFO_TEXT:
> Connection #2 to host geoportale-nhw-preprod.comune.roma.it
> Connection #5 to host geoportale-nhw-preprod.comune.roma.it
> Connection #3 to host geoportale-nhw-preprod.comune.roma.it
> Connection #1 to host geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it> left intactCPLError: Request
> for 220606604-223374076 failed with response_code=206ERROR 1: Request for
> 220606604-223374076 failed with response_code=206CPLError: Request for
> 223374078-226365702 failed with response_code=206ERROR 1: Request for
> 223374078-226365702 failed with response_code=206CPLError: Request for
> 226365704-226856674 failed with response_code=206ERROR 1: Request for
> 226365704-226856674 failed with response_code=206CPLError: Request for
> 226856676-228483196 failed with response_code=206ERROR 1: Request for
> 226856676-228483196 failed with response_code=206CPLError: Request for
> 228483198-229596738 failed with response_code=206ERROR 1: Request for
> 228483198-229596738 failed with response_code=206CPLError: Request for
> 229596740-230773941 failed with response_code=206ERROR 1: Request for
> 229596740-230773941 failed with response_code=206VSICURL: Download
> completedVSICURL: Downloading 220594176-221118463
> bytes=220594176-221118463CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial
> ContentCURL_INFO_HEADER_IN: Date: Wed, 10 Sep 2025 10:52:40
> 524287CURL_INFO_HEADER_IN: content-range:
> bytes=220594176-221118463CURL_INFO_HEADER_IN: accept-ranges:
> cookiesession2=63360d725398f949eeddf1157858c168;max-age=3600;Path=/;Secure;HttpOnlyCURL_INFO_HEADER_IN:
> CURL_INFO_TEXT: Connection cache is full, closing the oldest
> oneCURL_INFO_TEXT: Connection #0 to host
> response_code=206CPLError: TIFFFillTile:Read error at row 0, col 0, tile 1;
> got 15683 bytes, expected 580846ERROR 1: TIFFFillTile:Read error at row 0,
> col 0, tile 1; got 15683 bytes, expected 580846CPLError:
> TIFFReadEncodedTile() failed.ERROR 1: TIFFReadEncodedTile()
> failed.CPLError:
> band 1: IReadBlock failed at X offset 1, Y offset 0: TIFFReadEncodedTile()
> failed.ERROR 1:
> failed.GDAL:
> GDALClose(/vsicurl/https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
> this=0x59cab0e90a10)GDAL: In GDALDestroy - unloading GDAL shared library.*
> Luigi Pirelli
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250912/5296f7d8/attachment-0001.htm>
