[gdal-dev] Fail to get tiles from COG hosted in minio and served by a cogserver
Luigi Pirelli luipir at gmail.com
Tue Sep 16 03:31:01 PDT 2025
[SOLVED] :) and this is the report of what we found
- Thank you Even to point it out that our COG proxy range request was
giving back 1byte less
- Our test via differents client was affected by a mix of wrong and not
supported gdal vs rasterio versions
- This mismatch affected our titiler based on rio-tiler that was installed
in a older gdal base image.
The effect was that the COG server was working correctly, but the client
results in internal errors after a while of work.
Thank you to all who tried to help in some way.
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Book: Mastering QGIS3 - 3rd Edition
<https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
On Sat, 13 Sept 2025 at 17:24, Even Rouault <even.rouault at spatialys.com>
wrote:
> Luigi,
> This server doesn't implement HTTP range correctly. When sending a header
> "Range: bytes=X-Y", the server should return bytes from X to Y both
> included, so Y-X+1 bytes (cf
> https://datatracker.ietf.org/doc/html/rfc7233#section-2.1)
> But the server returns actually from X included to Y excluded, hence only
> Y-X bytes.
> Compare:
> $ curl -v -H "Range: bytes=0-1"
> "https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif"
> <https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif>
> --output -
> > Range: bytes=0-1
> < Content-Length: 1
> < content-range: bytes 0-1/810434714
> I
> vs
> "https:/download.osgeo.org/gdal/data/gtiff/utm.tif"
> <https:/download.osgeo.org/gdal/data/gtiff/utm.tif> --output -
> > Range: bytes=0-1
> < Content-Length: 2
> < Content-Range: bytes 0-1/262976
> II
> Even
> Le 10/09/2025 à 13:11, Luigi Pirelli via gdal-dev a écrit :
> Hi gdal comunity
> I'm asking help to understand some problems serving COG files via a custom
> COG server that hide the access to the files stored in an object store as
> Minio.
> the file is here:
> below the detailed log if accessing tiles and coping using gdal_translate.
> Server in the middle seems serving all partial request correctly without
> any warning about mismatch respect bytes requested and served, but in any
> case the copy ends with a bunch of
> *CPLError: Request for 220606604-223374076 failed with response_code=206 *
> errors.
> adding more strange behaviour i can see that this rasterio code:
> import rasterio
> import os
> os.environ["CPL_DEBUG"] = "ON"
> cog_url="
> with rasterio.open(cog_url) as dataset:
>     block_width, block_height = dataset.block_shapes[0]  # Block size
> (tile dimensions in pixels)
>     width = dataset.width
>     height = dataset.height
>     a_tile_window = rasterio.windows.Window(
>         col_off=width //2 , row_off=height //2, width=block_width-31,
> height=block_height-31
>     a_tile = dataset.read(1, window=a_tile_window)
> Give error if window is *block_width-31*, but not error if getting a
> *block_width-32* size
> any hint or help is appreciated
> thank you
> Luigi Pirelli
> GDAL_TRANSLATE LOG
> *12:52 $ gdal_translate
> /vsicurl/https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
> ~/Downloads/out.tif CPL: Loading configuration from
> /home/ginetto/.gdal/gdalrc CPL: Ignoring configuration option CPL_DEBUG=OFF
> from configuration file as it is already set as an environment variable
> CPL: Ignoring configuration option CPL_LOG_ERRORS=OFF from configuration
> file as it is already set as an environment variable HTTP: libcurl/8.5.0
> OpenSSL/3.0.13 zlib/1.3 brotli/1.1.0 zstd/1.5.5 libidn2/2.3.7 libpsl/0.21.2
> (+libidn2/2.3.7) libssh/0.10.6/openssl/zlib nghttp2/1.59.0 librtmp/2.3
> OpenLDAP/2.6.7 CURL_INFO_TEXT: Host
> geoportale-nhw-preprod.comune.roma.it:443
> <http://geoportale-nhw-preprod.comune.roma.it:443> was resolved.
> CURL_INFO_TEXT: IPv6: (none) CURL_INFO_TEXT: IPv4: 93.63.254.107
> CURL_INFO_TEXT:   Trying 93.63.254.107:443... CURL_INFO_TEXT: Connected to
> <http://geoportale-nhw-preprod.comune.roma.it> (93.63.254.107) port 443
> CURL_INFO_TEXT: ALPN: curl offers h2,http/1.1 CURL_INFO_TEXT: TLSv1.3
> (OUT), TLS handshake, Client hello (1): CURL_INFO_TEXT:  CAfile:
> /etc/ssl/certs/ca-certificates.crt CURL_INFO_TEXT:  CApath: /etc/ssl/certs
> CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Server hello (2):
> CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
> CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Certificate (11):
> CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, CERT verify (15):
> CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Finished (20): CURL_INFO_TEXT:
> TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1): CURL_INFO_TEXT:
> TLSv1.3 (OUT), TLS handshake, Finished (20): CURL_INFO_TEXT: SSL connection
> using TLSv1.3 / TLS_AES_256_GCM_SHA384 / X25519 / RSASSA-PSS
> CURL_INFO_TEXT: ALPN: server accepted http/1.1 CURL_INFO_TEXT: Server
> certificate: CURL_INFO_TEXT:  subject: C=IT; ST=Lazio; L=Roma; O=Roma
> Capitale; CN=*.comune.roma.it <http://comune.roma.it> CURL_INFO_TEXT:
>  start date: Dec 20 00:00:00 2024 GMT CURL_INFO_TEXT:  expire date: Jan  7
> 23:59:59 2026 GMT CURL_INFO_TEXT:  subjectAltName: host
> "geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it>" matched cert's
> "*.comune.roma.it <http://comune.roma.it>" CURL_INFO_TEXT:  issuer: C=US;
> O=DigiCert Inc; OU=www.digicert.com <http://www.digicert.com>; CN=GeoTrust
> TLS RSA CA G1 CURL_INFO_TEXT:  SSL certificate verify ok. CURL_INFO_TEXT:
> Certificate level 0: Public key type RSA (2048/112 Bits/secBits), signed
> using sha256WithRSAEncryption CURL_INFO_TEXT:   Certificate level 1: Public
> key type RSA (2048/112 Bits/secBits), signed using sha256WithRSAEncryption
> CURL_INFO_TEXT:   Certificate level 2: Public key type RSA (2048/112
> Bits/secBits), signed using sha256WithRSAEncryption CURL_INFO_TEXT: using
> HTTP/1.x CURL_INFO_TEXT: Server auth using Basic with user 'anonymous'
> CURL_INFO_HEADER_OUT: HEAD
> HTTP/1.1 Host: geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it> Authorization: Basic
> YW5vbnltb3VzOg== User-Agent: GDAL/3.8.4 Accept: */* CURL_INFO_TEXT: TLSv1.3
> (IN), TLS handshake, Newsession Ticket (4): CURL_INFO_TEXT: TLSv1.3 (IN),
> TLS handshake, Newsession Ticket (4): CURL_INFO_TEXT: old SSL session ID is
> stale, removing CURL_INFO_HEADER_IN: HTTP/1.1 200 OK CURL_INFO_HEADER_IN:
> Date: Wed, 10 Sep 2025 10:52:38 GMT CURL_INFO_HEADER_IN: Server: Apache
> CURL_INFO_HEADER_IN: Content-Length: 810434714 CURL_INFO_HEADER_IN:
> last-modified: 2025-07-17 16:23:21+00:00 CURL_INFO_HEADER_IN: etag:
> "a3b9bd1ae8c52585692c2bff1eda0171" CURL_INFO_HEADER_IN: Set-Cookie:
> cookiesession2=63360d725398f949eeddf1157658c168;max-age=3600;Path=/;Secure;HttpOnly
> cookiesession1=678B287018D2B682BD6915142E5A0D14;Expires=Thu, 10 Sep 2026
> 10:52:38 GMT;Path=/;Secure;HttpOnly CURL_INFO_HEADER_IN:
> Strict-Transport-Security: max-age=31536000 CURL_INFO_HEADER_IN:
> CURL_INFO_TEXT: Connection #0 to host geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it> left intact VSICURL:
> GetFileSize(https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif)=810434714
> <https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif)=810434714>
>  response_code=200 VSICURL: Downloading 0-16383
> (https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif).
> <https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif).>..
> CURL_INFO_TEXT: Found bundle for host: 0x59cab0e97790 [serially]
> CURL_INFO_TEXT: Can not multiplex, even if we wanted to CURL_INFO_TEXT:
> Re-using existing connection with host
> <http://geoportale-nhw-preprod.comune.roma.it> CURL_INFO_TEXT: Server auth
> using Basic with user 'anonymous' CURL_INFO_HEADER_OUT: GET
> YW5vbnltb3VzOg== User-Agent: GDAL/3.8.4 Accept: */* Range: bytes=0-16383
> CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial Content CURL_INFO_HEADER_IN:
> CURL_INFO_HEADER_IN: Content-Type: image/tiff; application=geotiff;
> profile=cloud-optimized CURL_INFO_HEADER_IN: Content-Length: 16383
> CURL_INFO_HEADER_IN: content-range: bytes=0-16383 CURL_INFO_HEADER_IN:
> accept-ranges: bytes CURL_INFO_HEADER_IN: Set-Cookie:
> CURL_INFO_HEADER_IN: Strict-Transport-Security: max-age=31536000
> CURL_INFO_HEADER_IN: CURL_INFO_TEXT: Connection #0 to host
> <http://geoportale-nhw-preprod.comune.roma.it> left intact VSICURL: Got
> response_code=206 GDAL:
> GDALOpen(/vsicurl/https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
> <https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif>,
> this=0x59cab0e90a10) succeeds as GTiff. GDAL: Using GTiff driver Input file
> size is 20544, 14016 GDAL: Using GTiff driver GTiff: ScanDirectories()
> VSICURL: Downloading 16384-49151
> bytes=16384-49151 CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial Content
> CURL_INFO_HEADER_IN: Date: Wed, 10 Sep 2025 10:52:38 GMT
> CURL_INFO_HEADER_IN: Server: Apache CURL_INFO_HEADER_IN: Content-Type:
> image/tiff; application=geotiff; profile=cloud-optimized
> CURL_INFO_HEADER_IN: Content-Length: 32767 CURL_INFO_HEADER_IN:
> content-range: bytes=16384-49151 CURL_INFO_HEADER_IN: accept-ranges: bytes
> response_code=206 GTiff: Opened 10272x7008 overview. GTiff: Opened
> 5136x3504 overview. GTiff: Opened 2568x1752 overview. GTiff: Opened
> 1284x876 overview. GTiff: Opened 642x438 overview. 0GDAL: GDAL_CACHEMAX =
> 4716 MB GDAL: GDALDatasetCopyWholeRaster(): 20544*512 swaths, bInterleave=1
> VSICURL: Downloading 220606604-223374076
> VSICURL: Downloading 223374078-226365702
> VSICURL: Downloading 226365704-226856674
> VSICURL: Downloading 226856676-228483196
> VSICURL: Downloading 228483198-229596738
> VSICURL: Downloading 229596740-230773941
> bytes=220606604-223374076 CURL_INFO_TEXT: Found bundle for host:
> 0x59cab0e97790 [serially] CURL_INFO_TEXT: Can not multiplex, even if we
> wanted to CURL_INFO_TEXT: Hostname geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it> was found in DNS cache
> CURL_INFO_TEXT:   Trying 93.63.254.107:443... CURL_INFO_TEXT: Found bundle
> for host: 0x59cab0e97790 [serially] CURL_INFO_TEXT: Can not multiplex, even
> if we wanted to CURL_INFO_TEXT: Hostname
> CURL_INFO_TEXT: Connected to geoportale-nhw-preprod.comune.roma.it
> profile=cloud-optimized CURL_INFO_HEADER_IN: Content-Length: 2767472
> CURL_INFO_HEADER_IN: content-range: bytes=220606604-223374076
> CURL_INFO_HEADER_IN: accept-ranges: bytes CURL_INFO_HEADER_IN: Set-Cookie:
> CURL_INFO_HEADER_IN: CURL_INFO_TEXT: Connected to
> bytes=226856676-228483196 CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> Server hello (2): CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Encrypted
> Extensions (8): CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Certificate
> (11): CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, CERT verify (15):
> bytes=228483198-229596738 CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> bytes=229596740-230773941 CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> bytes=223374078-226365702 CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> bytes=226365704-226856674 CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> Newsession Ticket (4): CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> Newsession Ticket (4): CURL_INFO_TEXT: old SSL session ID is stale,
> removing CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Newsession Ticket
> (4): CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
> CURL_INFO_TEXT: old SSL session ID is stale, removing CURL_INFO_TEXT:
> TLSv1.3 (IN), TLS handshake, Newsession Ticket (4): CURL_INFO_TEXT: old SSL
> session ID is stale, removing CURL_INFO_TEXT: TLSv1.3 (IN), TLS handshake,
> CURL_INFO_TEXT: old SSL session ID is stale, removing CURL_INFO_HEADER_IN:
> HTTP/1.1 206 Partial Content CURL_INFO_HEADER_IN: Date: Wed, 10 Sep 2025
> 10:52:38 GMT CURL_INFO_HEADER_IN: Server: Apache CURL_INFO_HEADER_IN:
> Content-Type: image/tiff; application=geotiff; profile=cloud-optimized
> CURL_INFO_HEADER_IN: Content-Length: 1626520 CURL_INFO_HEADER_IN:
> content-range: bytes=226856676-228483196 CURL_INFO_HEADER_IN:
> cookiesession2=d17e9524a2e2bd46eeddf1157658c168;max-age=3600;Path=/;Secure;HttpOnly
> cookiesession1=678B28700CB3ACBDE48CB06AABF53369;Expires=Thu, 10 Sep 2026
> profile=cloud-optimized CURL_INFO_HEADER_IN: Content-Length: 1113540
> CURL_INFO_HEADER_IN: content-range: bytes=228483198-229596738
> cookiesession1=678B28701369CC6FF14EFC0F7C49DEE6;Expires=Thu, 10 Sep 2026
> Date: Wed, 10 Sep 2025 10:52:39 GMT CURL_INFO_HEADER_IN: Server: Apache
> profile=cloud-optimized CURL_INFO_HEADER_IN: Content-Length: 2991624
> CURL_INFO_HEADER_IN: content-range: bytes=223374078-226365702
> cookiesession2=d17e9524a2e2bd46eeddf1157758c168;max-age=3600;Path=/;Secure;HttpOnly
> cookiesession1=678B28708EB2D0D778D6A3C28D0B2FE0;Expires=Thu, 10 Sep 2026
> 10:52:39 GMT;Path=/;Secure;HttpOnly CURL_INFO_HEADER_IN:
> profile=cloud-optimized CURL_INFO_HEADER_IN: Content-Length: 490970
> CURL_INFO_HEADER_IN: content-range: bytes=226365704-226856674
> cookiesession2=63360d725398f949eeddf1157758c168;max-age=3600;Path=/;Secure;HttpOnly
> cookiesession1=678B28708E661F83CF8066E206817AAA;Expires=Thu, 10 Sep 2026
> profile=cloud-optimized CURL_INFO_HEADER_IN: Content-Length: 1177201
> CURL_INFO_HEADER_IN: content-range: bytes=229596740-230773941
> cookiesession1=678B287076DD1049BDA4DB2C6294E06F;Expires=Thu, 10 Sep 2026
> CURL_INFO_TEXT: Connection #4 to host geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it> left intact CURL_INFO_TEXT:
> Connection #2 to host geoportale-nhw-preprod.comune.roma.it
> Connection #5 to host geoportale-nhw-preprod.comune.roma.it
> Connection #3 to host geoportale-nhw-preprod.comune.roma.it
> Connection #1 to host geoportale-nhw-preprod.comune.roma.it
> <http://geoportale-nhw-preprod.comune.roma.it> left intact CPLError:
> Request for 220606604-223374076 failed with response_code=206 ERROR 1:
> Request for 220606604-223374076 failed with response_code=206 CPLError:
> Request for 223374078-226365702 failed with response_code=206 ERROR 1:
> Request for 223374078-226365702 failed with response_code=206 CPLError:
> Request for 226365704-226856674 failed with response_code=206 ERROR 1:
> Request for 226365704-226856674 failed with response_code=206 CPLError:
> Request for 226856676-228483196 failed with response_code=206 ERROR 1:
> Request for 226856676-228483196 failed with response_code=206 CPLError:
> Request for 228483198-229596738 failed with response_code=206 ERROR 1:
> Request for 228483198-229596738 failed with response_code=206 CPLError:
> Request for 229596740-230773941 failed with response_code=206 ERROR 1:
> Request for 229596740-230773941 failed with response_code=206 VSICURL:
> Download completed VSICURL: Downloading 220594176-221118463
> bytes=220594176-221118463 CURL_INFO_HEADER_IN: HTTP/1.1 206 Partial Content
> CURL_INFO_HEADER_IN: Date: Wed, 10 Sep 2025 10:52:40 GMT
> CURL_INFO_HEADER_IN: Content-Length: 524287 CURL_INFO_HEADER_IN:
> content-range: bytes=220594176-221118463 CURL_INFO_HEADER_IN:
> cookiesession2=63360d725398f949eeddf1157858c168;max-age=3600;Path=/;Secure;HttpOnly
> CURL_INFO_HEADER_IN: CURL_INFO_TEXT: Connection cache is full, closing the
> oldest one CURL_INFO_TEXT: Connection #0 to host
> response_code=206 CPLError: TIFFFillTile:Read error at row 0, col 0, tile
> 1; got 15683 bytes, expected 580846 ERROR 1: TIFFFillTile:Read error at row
> 0, col 0, tile 1; got 15683 bytes, expected 580846 CPLError:
> TIFFReadEncodedTile() failed. ERROR 1: TIFFReadEncodedTile() failed.
> CPLError:
> band 1: IReadBlock failed at X offset 1, Y offset 0: TIFFReadEncodedTile()
> failed. ERROR 1:
> failed. GDAL:
> GDALClose(/vsicurl/https://geoportale-nhw-preprod.comune.roma.it/aerofototeca-api/integration/api/tile?filename=/roma/2022/Roma_2022/6020/6020-Lvl02-Color.tif
> this=0x59cab0e90a10) GDAL: In GDALDestroy - unloading GDAL shared library.*
> Luigi Pirelli
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250916/15854bbe/attachment-0001.htm>
