[gdal-dev] Geolocation arrays - location interpretation
Michele
clearlymichele at yahoo.com
Tue Sep 16 08:46:47 PDT 2025
Can someone unsubscribe me from this please?
On Thursday, September 28, 2017 at 03:26:01 PM EDT, Even Rouault <even.rouault at spatialys.com> wrote:
On jeudi 28 septembre 2017 17:26:52 CEST Agram, Piyush S (334D) wrote:
> Hi Even,
> I think I have figured out how the GeoLocTransformer works. Dumped out
> the backmap and might have some changes.
> 1) Rounding up to the nearest integer is definitely the issue here.
> 2) I’m going to try this first – maybe a weighted approach will be
> better. For now, if a pixel falls in the middle of square – I’m going to
> add it to all of the 4 vertices. Then average all the data that went into a
> pixel of the backmap.
Perhaps bilinear resampling so that the weights are proportionnal ?
> 3) For the regular grid tests, if this shows improvement (hopefully) –
> I can share the implementation and we can possibly discuss about adding a
> weighting scheme. I don’t want to increase the runtime too much by adding
> complexity.
I think (sub-pixel) accuracy is more important than speed. Speed improvements can be investigated later if needed.
http://www.spatialys.com
gdal-dev mailing list
gdal-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250916/f49cfeec/attachment.htm>
