[gdal-dev] Problem building GDAL 3.8.3 with MrSID SDK on SLES 15 SP6
Fernando Quadro fsquadro at gmail.com
Thu Sep 25 07:55:21 PDT 2025
Hi all,
I am trying to build *GDAL 3.8.3* on *SUSE Linux Enterprise Server 15 SP6*
with support for the *MrSID DSDK 9.5.5.5244 (RHEL9 x86-64, gcc1131)*.
My steps so far:
   1.
   Installed the SDK under /opt/MrSID/current/Raster_DSDK.
      Includes: /opt/MrSID/current/Raster_DSDK/include
      Libs: /opt/MrSID/current/Raster_DSDK/lib/libltidsdk.so (with libtbb.so
      included).
      2.
   Configured CMake with:
   cmake .. \
     -DCMAKE_BUILD_TYPE=Release \
     -DCMAKE_INSTALL_PREFIX=/usr/local \
     -DGDAL_USE_MRSID=ON \
     -DGDAL_ENABLE_DRIVER_MRSID_PLUGIN=ON \
     -DMRSID_INCLUDE_DIR=/opt/MrSID/current/Raster_DSDK/include \
     -DMRSID_LIBRARY=/opt/MrSID/current/Raster_DSDK/lib/libltidsdk.so \
     -DGDAL_BUILD_OPTIONAL_DRIVERS=ON \
     -DGDAL_ENABLE_PLUGINS=ON
   The configure step detects MrSID correctly:
   -- Found MRSID: /opt/MrSID/current/Raster_DSDK/lib/libltidsdk.so
(found version "9.5.5")
   -- Enabled driver: gdal_MRSID
   3.
   Built and installed GDAL (libgdal.so shows MrSID symbols when inspected
   with strings).
   Example:
   strings /usr/local/lib64/libgdal.so | grep -i mrsid
   GDALRegister_MrSID
   MrSID driver
   4.
   Verified dependencies:
   ldd /usr/local/lib64/libgdal.so | grep ltidsdk
   /opt/MrSID/current/Raster_DSDK/lib/libltidsdk.so (0x00007f9829a00000)
*Problem:*
Even after build and install, gdalinfo --formats does *not list the MrSID
driver*.
Therefore, GeoServer (which loads GDAL via JNI) also does not detect MrSID.
*Question:*
   Did I miss an additional CMake flag (e.g., to force building the driver
   as a plugin instead of static)?
   Should the gdal_MrSID driver be compiled as a .so plugin under
   /usr/local/lib64/gdalplugins/, or linked directly into libgdal.so?
   Any known issues when building the MrSID driver against GCC 7 (default
   on SLES 15 SP6) or should I rebuild with a newer GCC?
Thanks a lot for any hints,
Fernando Quadro
http://www.fernandoquadro.com.br
https://www.linkedin.com/in/fernandoquadro/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250925/bbdfd7e1/attachment-0001.htm>
