[gdal-dev] gdal2tiles 3.11.3 dies when source files have transparency
Stefan Gofferje lists at home.gofferje.net
Mon Sep 29 08:41:48 PDT 2025
Hi all,
I have 4 large GeoTIFF files from which I want to create XYZ tiles. I
have tried various combinations with gdal_merge, gdalbuildvrt and
gdal_translate and the result is the same:
When the source file contains transparency such as
gdalbuildvrt -srcnodata 0 VVVH.vrt ${LIST}
gdal_merge -n 0 -a_nodata 0 -o VVVH.tif ${LIST}
etc...
gdal2tiles dies complaining that the source file cannot be found in the
/tmp directory.
I call gdal2tiles like this:
/usr/bin/gdal2tiles -x --processes 8 --xyz -z 8-14 VVVH.vrt tiles
or
/usr/bin/gdal2tiles -x --processes 8 --xyz -z 8-14 VVVH.tif tiles
depending on what source file I created.
I really would like to have tiles which are transparent where the source
files are instead of black.
Example output:
0multiprocessing.pool.RemoteTraceback:
   File "/usr/lib/python3.12/multiprocessing/pool.py", line 125, in worker
     result = (True, func(*args, **kwds))
   File "/usr/lib/python3.12/multiprocessing/pool.py", line 48, in mapstar
     return list(map(*args))
   File "/usr/lib/python3/dist-packages/osgeo_utils/gdal2tiles.py", line
1335, in create_base_tile
     alpha = alphaband.ReadRaster(rx, ry, rxsize, rysize, wxsize, wysize)
   File "/usr/lib/python3/dist-packages/osgeo/gdal.py", line 8756, in
ReadRaster
     return _gdal.Band_ReadRaster1(self, xoff, yoff, xsize, ysize,
RuntimeError: /tmp/tmpg8iuy420/VVVH.tif: No such file or directory
May be caused by: /tmp/tmpg8iuy420/VVVH.tif: No such file or directory
The above exception was the direct cause of the following exception:
   File "/usr/bin/gdal2tiles", line 33, in <module>
     sys.exit(load_entry_point('GDAL==3.11.3', 'console_scripts',
'gdal2tiles')())
4625, in main
     return submain(argv, called_from_main=called_from_main)
   File "/usr/lib/python3/dist-packages/osgeo_utils/auxiliary/util.py",
line 46, in enable_exceptions_wrapper
     return fun(*args, **kwargs)
4655, in submain
     multi_threaded_tiling(input_file, output_folder, options, pool)
4549, in multi_threaded_tiling
     for _ in pool.imap_unordered(
   File "/usr/lib/python3.12/multiprocessing/pool.py", line 451, in
<genexpr>
     return (item for chunk in result for item in chunk)
   File "/usr/lib/python3.12/multiprocessing/pool.py", line 873, in next
     raise value
  (o_   Stefan Gofferje            | SCLT, MCP, CCSA
  //\   Reg'd Linux User #247167   | VCP #2263
  V_/_  https://www.gofferje.net   | https://www.saakeskus.fi
