[gdal-dev] Generating Python Bindings for GDAL 3.11.4
Mazin Marwan mazin.marwan0 at gmail.com
Mon Sep 29 15:08:19 PDT 2025
Hi all,
I've installed GDAL 3.11.4 using VCPKG and am now trying to generate the
python bindings using:
pip install gdal
However I'm running into the following error:
ERROR: Failed building wheel for gdal
Failed to build gdal
error: failed-wheel-build-for-install
× Failed to build installable wheels for some pyproject.toml based projects
╰─> gdal
A bit of research online has led me to believe that the pip version is just
broken and that the fix is installing a .whl file from cgholke's geospatial
wheels repo but that seems like a workaround instead of a proper fix. Is
there another way to fix this?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250929/dff8053d/attachment-0001.htm>
