[gdal-dev] Coordinate transformation of geometries between CRSs with different axis ordering (C API)
Florian Katerndahl
florian at katerndahl.com
Wed Apr 1 07:04:36 PDT 2026
Dear all,
I'm currently working on a small program which allows users to specify
vector inputs in different coordinates systems and that potentially
"normalizes" them to EPSG:4326 internally to process them further. Maybe
I'm too inexperienced and there's an easy solution but I got hung up on
the coordinate transformation when the input CRS has a different axis
ordering compared to the output CRS using GDAL's/OGR's C API.
For example, transforming between EPSG:5556 and EPSG:4326, GDAL outputs
a warning (forwarded from proj?) that the output's latitude is invalid.
Setting the axis ordering of the target CRS to
`OAMS_TRADITIONAL_GIS_ORDER` fixes this and results in correctly located
polygons. My question is now: Is it sufficient/correct to compare the
axis ordering of the input and output coordinate systems and set above
mentioned flag (or a custom mapping when neither "x"/"y" are the first
two axis) in case they differ?
Kind regards and many thanks in advance,
Florian Katerndahl
