[gdal-dev] ogrinfo vs gdal vector info equivalent command
Scott
public at postholer.com
Wed Apr 1 17:58:26 PDT 2026
Greetings!
What is the equivalent 'gdal vector info' (or other CLI) command to the
older ogrinfo syntax?
ogrinfo -dialect sqlite -sql "create index if not exists mytable_col_idx
on mytable(col)" source.gpkg
The above works fine, the following errors out:
gdal vector info --dialect sqlite --sql "create index mytable_col_idx on
ERROR 1: In ExecuteSQL(): sqlite3_step(create index mytable_col_idx on
mytable(col)):
attempt to write a readonly database
I'm struggling with this and have continued to use the old ogrinfo.
Thanks!
Scott
www.postholer.com
