[gdal-dev] ogrinfo vs gdal vector info equivalent command
Scott
public at postholer.com
Wed Apr 1 18:16:53 PDT 2026
Worked perfect. I tried it with 'gdal vector sql' also, but it was the
--update I was missing.
Thanks Even!
On 4/1/26 18:03, Even Rouault wrote:
> Scott,
> you don't want info, you want to run a sql command. So gdal vector
> sql ! And as you perform modifications, you need to provide explicit --
> update
> gdal vector sql --update --sql "create index mytable_col_idx on
> mytable(col)" source.gpkg
> Even
> Le 02/04/2026 à 02:58, Scott via gdal-dev a écrit :
>> Greetings!
>> What is the equivalent 'gdal vector info' (or other CLI) command to
>> the older ogrinfo syntax?
>> ogrinfo -dialect sqlite -sql "create index if not exists
>> mytable_col_idx on mytable(col)" source.gpkg
>> The above works fine, the following errors out:
>> gdal vector info --dialect sqlite --sql "create index mytable_col_idx
>> ERROR 1: In ExecuteSQL(): sqlite3_step(create index mytable_col_idx on
>> mytable(col)):
>> attempt to write a readonly database
>> I'm struggling with this and have continued to use the old ogrinfo.
>> Thanks!
>> Scott
