[gdal-dev] Trouble building GDAL 3.12.3 on Linux
Andrew Bell
andrew.bell.ia at gmail.com
Mon Apr 6 08:47:26 PDT 2026
Hi Carl,
The actual build command from the failing step might be helpful.
On Mon, Apr 6, 2026 at 11:33 AM Carl Godkin via gdal-dev
<gdal-dev at lists.osgeo.org> wrote:
> Hi,
> I'm updating our GDAL and other third party libraries. I'm usually pretty adept at this but I am having a problem building GDAL 3.12.3 on Linux RHEL8 with GCC 13.2.
> The shared library builds okay, but once we get to the apps, I am getting undefined references to two PROJ functions (proj_coordinate_metadata_create & proj_crs_has_point_motion_operation).
> I was struggling with this last Friday with PROJ 9.8.0 but, after this weekend's advice about ETRS89, I switched to PROJ 9.7.1 where I'm having the same problem.
> I haven't seen any similar questions go by and I am stuck. Any advice?
> My GDAL 3.12.3 cmake command looks like this:
> cmake \
> -DCMAKE_BUILD_TYPE=Release \
> -DCMAKE_C_COMPILER:FILEPATH=/usr/local/gcc132/bin/gcc \
> -DCMAKE_CXX_COMPILER:FILEPATH=/usr/local/gcc132/bin/g++ \
> -DCMAKE_POSITION_INDEPENDENT_CODE=ON \
> -DCMAKE_INSTALL_PREFIX=/usr/local/devlibs/gdal-3.12.3 \
> -DBUILD_JAVA_BINDINGS:BOOL=OFF \
> -DSQLite3_INCLUDE_DIR=/usr/local/devlibs/sqlite-3.51.3/include \
> -DSQLite3_LIBRARY=/usr/local/devlibs/sqlite-3.51.3/lib/libsqlite3.so \
> -DARCHIVE_INCLUDE_DIR=/usr/local/devlibs/libarchive-3.8.6/include \
> -DARCHIVE_LIBRARY=/usr/local/devlibs/libarchive-3.8.6/lib64/libarchive.so \
> -DCURL_INCLUDE_DIR=/usr/local/devlibs/curl-8.4.0/include \
> -DCURL_LIBRARY_RELEASE=/usr/local/devlibs/curl-8.4.0/lib64/libcurl.so \
> -DPROJ_INCLUDE_DIR=/usr/local/devlibs/proj-9.7.1/include \
> -DPROJ_LIBRARY_RELEASE=/usr/local/devlibs/proj-9.7.1/lib64/libproj.so \
> -DGDAL_USE_GEOTIFF_INTERNAL:BOOL=ON \
> -DGDAL_USE_WEBP_INTERNAL:BOOL=ON \
> -DMRSID_INCLUDE_DIR=/usr/local/devlibs/MrSID_DSDK-9.5.4.4709-rhel6.x86-64.gcc531/Raster_DSDK/include \
> -DMRSID_LIBRARY=/usr/local/devlibs/MrSID_DSDK-9.5.4.4709-rhel6.x86-64.gcc531/Raster_DSDK/lib/libltidsdk.so \
> -DGDAL_ENABLE_DRIVER_JP2MRSID=ON \
> and my PROJ 9.7.0 is pretty basic, and looks like this:
> cmake \
> -Wno-dev -Wno-deprecated \
> -DCMAKE_INSTALL_PREFIX=/usr/local/devlibs/proj-9.7.1 \
> Thank you very much,
> carl
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Andrew Bell
