[gdal-dev] Trouble building GDAL 3.12.3 on Linux
Carl Godkin
cgodkin at gmail.com
Mon Apr 6 09:42:15 PDT 2026
Thanks to Seabastiaan's advice, I've rerun the cmake command and now the
"make" gives this for the failing step:
[ 95%] Linking CXX executable test_ogrsf
cd /home/carl/build/gdal-3.12.3/linux64_build/apps && /usr/bin/cmake -E
cmake_link_script CMakeFiles/test_ogrsf.dir/link.txt --verbose=1
/usr/local/gcc132/bin/g++ -fvisibility=hidden -O3 -DNDEBUG
CMakeFiles/test_ogrsf.dir/test_ogrsf.cpp.o -o test_ogrsf
-Wl,-rpath,/home/carl/build/gdal-3.12.3/linux64_build
../libgdal.so.38.3.12.3
/net/raid1/home/local64-rhel8/gcc132-rhel8/bin/../lib/gcc/x86_64-pc-linux-gnu/13.2.0/../../../../x86_64-pc-linux-gnu/bin/ld:
../libgdal.so.38.3.12.3: undefined reference to
`proj_coordinate_metadata_create'
`proj_crs_has_point_motion_operation'
collect2: error: ld returned 1 exit status
make[2]: *** [apps/CMakeFiles/test_ogrsf.dir/build.make:101:
apps/test_ogrsf] Error 1
make[2]: Leaving directory '/home/carl/build/gdal-3.12.3/linux64_build'
make[1]: *** [CMakeFiles/Makefile2:8647:
apps/CMakeFiles/test_ogrsf.dir/all] Error 2
make[1]: Leaving directory '/home/carl/build/gdal-3.12.3/linux64_build'
make: *** [Makefile:149: all] Error 2
Does that help? Thanks a lot,
carl
On Mon, Apr 6, 2026 at 9:28 AM Sebastiaan Couwenberg <sebastic at xs4all.nl>
wrote:
> On 4/6/26 6:12 PM, Carl Godkin via gdal-dev wrote:
> > Thanks for the reply. The actual command is always hidden by cmake. (I
> > am obviously not a cmake expert!) Is there a way to get it to reveal
> more?
> -DCMAKE_VERBOSE_MAKEFILE=ON
> https://cmake.org/cmake/help/latest/variable/CMAKE_VERBOSE_MAKEFILE.html
> Kind Regards,
> Bas
> PGP Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260406/fee7e6a9/attachment.htm>
