[gdal-dev] CSHARP: Proposal to Remove Mono from the CMAKE build scripts
Paul Harwood
runette at gmail.com
Wed Apr 15 10:00:18 PDT 2026
However, it is not necessary to build in Mono for the libraries to run on
Mono. The libraries can be compiled using dotnet and consumed by Mono - I
have doing that for many years for Unity.
On Wed, 15 Apr 2026, 17:57 Paul Harwood, <runette at gmail.com> wrote:
> See https://www.mono-project.com/
> Microsoft has been the de facto owner of Mono for 10 years.
> On Wed, 15 Apr 2026, 17:43 Andrew Bell, <andrew.bell.ia at gmail.com> wrote:
>> On Wed, Apr 15, 2026 at 12:27 PM Paul Harwood via gdal-dev
>> <gdal-dev at lists.osgeo.org> wrote:
>> > I have created an RFC to propose that we remove support for building in
>> Mono using mcs from the CMAKE build scripts for the C# bindings.
>> > https://github.com/OSGeo/gdal/pull/14368
>> > The CMAKE build scripts grandfathered in support for this from the
>> previous build system.
>> > Mono is deprecated by Microsoft and the advice is to use dotnet on all
>> platforms - which include all platforms we support with the build scripts.
>> I thought Mono was an *alternative* to the Microsoft ecosystem for MS
>> VM/CLI/etc., so saying that it's "deprecated by Microsoft" seems like
>> a strange statement, but I'm not up on the latest news.
>> Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260415/e19a4bf0/attachment-0001.htm>
