[gdal-dev] CLI API: specify names for an input DATASET_LIST of objects (e.g., raster calc)?
Even Rouault
even.rouault at spatialys.com
Mon Apr 20 01:39:24 PDT 2026
Chris,
you will need to use
/** Bit indicating that the name component of GDALArgDatasetValue is
accepted. */
#define GADV_NAME (1 << 0)
/** Bit indicating that the dataset component of GDALArgDatasetValue is
accepted. */
#define GADV_OBJECT (1 << 1)
int CPL_DLL GDALAlgorithmArgGetDatasetInputFlags(GDALAlgorithmArgH);
latest master with commit
https://github.com/OSGeo/gdal/commit/a723bb54b290ac206c77ca505fec27fb31b0ed97
But raster calc is a bit cheating. Normally the name accepted
by GDALArgDatasetValue should be a regular dataset name note
name=dataset_name.
Even
Le 20/04/2026 à 04:30, Chris Toney via gdal-dev a écrit :
> Hi,
> "raster calc" takes DATASET_LIST input that may be objects in API
> usage. Calc inputs must be named when more than one is provided. The
> syntax '[<name>=]<input>' is used for datasets given as text DSNs or
> nested pipeline statements. I can't tell whether it's possible to
> specify a list of names when the DATASET_LIST is given as a vector of
> `GDALDatasetH*` in API usage.
> Thanks.
> Chris
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
