[gdal-dev] Compound CRS
Norman Barker
norman.barker at gmail.com
Thu Apr 23 17:08:00 PDT 2026
I am trying to use a compound CRS in GDAL. I have a CRS that is essentially
topocentric but with an angle and skew applied to the tangential plane by
two unit vectors uiax and uiay.
I am doing this in Python and the code is as follows;
# planar angle between unit vector and northing in topocentric
theta = np.arccos(np.clip(np.dot(uiay[:2], [0, 1]), -1.0, 1.0))
# planar angle between unit vector and easting in topocentric
phi = np.arccos(np.clip(np.dot(uiax[:2], [1, 0]), -1.0, 1.0))
# Build rotation matrix
rot = np.array([
[np.cos(theta), -np.sin(theta), 0.0, 0.0],
[np.sin(theta), np.cos(theta), 0.0, 0.0],
[ 0.0, 0.0, 1.0, 0.0],
[ 0.0, 0.0, 0.0, 1.0],
# Build shear/skew matrix
m = np.tan(phi)
skew = np.array([
[1.0, 0.0, 0.0, 0.0],
[ m, 1.0, 0.0, 0.0],
[0.0, 0.0, 1.0, 0.0],
[0.0, 0.0, 0.0, 1.0],
# get affine transform
a = rot @ skew
wgs84 = osr.SpatialReference(epsg=4326)
wgs84.SetAxisMappingStrategy(osr.OAMS_TRADITIONAL_GIS_ORDER)
topo = osr.SpatialReference(f"+proj=pipeline "
f"+step +proj=topocentric +X_0={
ref_ecf[0]} +Y_0={ref_ecf[1]} +Z_0={ref_ecf[2]} "
f"+step +proj=affine "
f"+s11={a[0,0]} +s12={a[0,1]} +s13={
a[0,2]} "
f"+s21={a[1,0]} +s22={a[1,1]} +s23={
a[1,2]} "
f"+s31={a[2,0]} +s32={a[2,1]} +s33={
a[2,2]} "
ct = osr.CoordinateTransformation(topo, wgs84)
I get the error message "ERROR 1: PROJ: proj_crs_get_coordinate_system:
Object is not a SingleCRS"
Which is true, it is not. I have grep'd the tests and have not seen any
examples. Using `CoordinateTransformationOptions` applies once the
conversion to lat/lon is complete.
Thanks,
Norman
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260423/01d040b5/attachment.htm>
