[gdal-dev] Two resolutions for one GTI
Even Rouault even.rouault at spatialys.com
Thu Apr 30 13:46:48 PDT 2026
Pete,
> What is the expected value if my GTI references two (or more) files at
> different resolutions? Should I set RESX and RESY to the highest
> resolution data?
It is entirely up to you to decide which resolution you want to be
exposed. The highest one is a very reasonable strategy.
> Does GTI support a collection of rasters which might be at different
> resolutions?
Yes, it will down-sample/up-sample as needed.
Even
http://www.spatialys.com
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
