[gdal-dev] gdal-dev Digest, Vol 267, Issue 6
Bhanu Gundugollu
bgundugo at gmail.com
Tue Aug 18 00:05:28 PDT 2026
On Fri, Aug 14, 2026 at 5:58 AM <gdal-dev-request at lists.osgeo.org> wrote:
> Send gdal-dev mailing list submissions to
> gdal-dev at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> gdal-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of gdal-dev digest..."
> Today's Topics:
> 1. Re: AutoIdentifyEPSG() fails on standard ESRI-dialect
> NAD83/UTM .prj (proj_identify succeeds); FindMatches() also
> missing from Java bindings (Barry DeZonia)
> Message: 1
> Date: Thu, 13 Aug 2026 19:28:00 -0500
> From: Barry DeZonia <bdezonia at gmail.com>
> To: Tom Moore <tmoore at spatial.ca>
> Cc: Even Rouault <even.rouault at spatialys.com>,
> Subject: Re: [gdal-dev] AutoIdentifyEPSG() fails on standard
> ESRI-dialect NAD83/UTM .prj (proj_identify succeeds); FindMatches()
> also missing from Java bindings
> Message-ID:
> <CAKcvfuT0AFzHboG8uiWwkGZ6MowhfjUUtQZPB4gvBmeX=
> CAONQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> One maybe nonsense question: where does panConfidence4 come from? Are you
> using an undeclared variable?
> On Thu, Aug 13, 2026 at 7:24?PM Barry DeZonia <bdezonia at gmail.com> wrote:
> > My foggy memory tells me that this looks good. I will let you and
> > Even figure out the PR issue.
> > On Thu, Aug 13, 2026 at 6:56?PM Tom Moore <tmoore at spatial.ca> wrote:
> >> Thanks for offering to take a look. I have a working draft already, but
> >> I'm not sure if I'm taking the right approach and could use a review.
> >> The signature translation itself is the easy part. The C# binding in
> >> osr.i was an almost perfect example, and this is what I changed it to:
> >> #ifdef SWIGJAVA
> >> OSRSpatialReferenceShadow** FindMatches( char** options, int*
> >> nvalues, int** confidence_values )
> >> return (OSRSpatialReferenceShadow**) OSRFindMatches(self,
> >> options, nvalues, confidence_values);
> >> #endif
> >> Everything interesting (haha, challenging) turned out to be in
> >> typemaps_java.i, getting SWIG to actually expose that return value and
> the
> >> two output parameters sensibly in Java. I haven't used swig in a long
> >> time, so I had forgotten most of the incantations. Llm to the rescue.
> >> Here is the addition to typemaps_java.i:
> >> == start ==
> >> %typemap(in,numinputs=0) int* nvalues (int nMatches = 0)
> >> /* %typemap(in,numinputs=0) int* nvalues */
> >> $1 = &nMatches;
> >> %typemap(in) int** confidence_values (int* panConfidence = NULL)
> >> /* %typemap(in) int** confidence_values. Ignore the input,
> >> keep $input around so argout can write the real
> >> result into element [0]. */
> >> $1 = &panConfidence;
> >> %typemap(argout) int** confidence_values
> >> /* %typemap(argout) int** confidence_values will fill the caller's
> >> int[][] */
> >> if ($input && jenv->GetArrayLength($input) >= 1) {
> >> jintArray confArray = jenv->NewIntArray(nMatches3);
> >> jenv->SetIntArrayRegion(confArray, 0, nMatches3,
> >> (jint*)panConfidence4);
> >> jenv->SetObjectArrayElement($input, 0, confArray);
> >> jenv->DeleteLocalRef(confArray);
> >> CPLFree(panConfidence4);
> >> %typemap(jni) int** confidence_values "jobjectArray"
> >> %typemap(jtype) int** confidence_values "int[][]"
> >> %typemap(jstype) int** confidence_values "int[][]"
> >> %typemap(javain) int** confidence_values "$javainput"
> >> %typemap(out) (OSRSpatialReferenceShadow**)
> >> const jclass srsClass =
> >> jenv->FindClass("org/gdal/osr/SpatialReference");
> >> const jmethodID srsCtor = jenv->GetMethodID(srsClass, "<init>",
> >> "(JZ)V");
> >> jresult = jenv->NewObjectArray(nMatches3, srsClass, NULL);
> >> for (int i = 0; i < nMatches3; i++) {
> >> OSRReference(result[i]);
> >> jobject srsObj = jenv->NewObject(srsClass, srsCtor,
> (jlong)result[i],
> >> (jboolean)true);
> >> jenv->SetObjectArrayElement(jresult, i, srsObj);
> >> jenv->DeleteLocalRef(srsObj);
> >> OSRFreeSRSArray(result);
> >> %typemap(jni) OSRSpatialReferenceShadow** "jobjectArray"
> >> %typemap(jtype) OSRSpatialReferenceShadow**
> >> "org.gdal.osr.SpatialReference[]"
> >> %typemap(jstype) OSRSpatialReferenceShadow**
> >> %typemap(javaout) OSRSpatialReferenceShadow** {
> >> return $jnicall;
> >> == end ==
> >> The nvalues argument stays hidden (numinputs=0), while confidence_values
> >> becomes visible as an int[][] out-box, following the same
> >> caller-passes-a-1-element-array-and-we-fill-it idiom already used
> elsewhere
> >> in typemaps_java.i (the GDALDimensionHS** pattern was the model here).
> >> SWIG auto-suffixes typemap-declared local variables with the argument's
> >> position in the full parameter list to avoid collisions. FOr example, a
> >> variable I declared as (int nMatches = 0) inside the nvalues typemap
> >> (argument position 3) actually gets emitted into the generated code as
> >> nMatches3, not nMatches. This isn't visible from the .i source at all, I
> >> only found it by examining the generated osr_wrap.cpp after a failed
> >> compile. Any other typemap block that needs to reference that same
> variable
> >> (the argout/out blocks) has to hardcode the anticipated suffixed name
> >> directly because SWIG doesn't rewrite references for you.
> >> End result:
> >> public SpatialReference[] FindMatches(Vector options, int[][]
> >> confidenceValuesOut)
> >> The function returns an array of matches (SpatialReference[] as
> >> OSRSpatialReferenceShadow**), which is the primary thing that you want
> to
> >> get from this function.
> >> How to use:
> >> int[][] confidence = new int[1][];
> >> SpatialReference[] matches = srs.FindMatches(null, confidence);
> >> int[] confidenceValues = confidence[0];
> >> Patched against the current master. Tested on against an esri shapefile
> >> .prj (ESRI-dialect NAD83 / UTM zone 11N WKT) that AutoIdentifyEPSG()
> fails
> >> on with 'Unsupported SRS' -- FindMatches() correctly returns a single
> >> match, EPSG:26911, with confidence[0][0] = 100, matching projinfo
> >> --identify exactly on the same input. Not tested any further than that.
> >> How does this look so far? Is this going in the right direction? If
> so,
> >> what would it take to turn this into an acceptable PR?
> >> Thanks again for your help, and full disclosure, thanks to llm for
> >> significant assistance on this.
> >> Tom
> >> On Thu, Aug 13, 2026, at 5:16 PM, Barry DeZonia wrote:
> >> AI is helping me remember
> >> for the FindMatches() routine would you want it matching as close as
> >> possible C types or would you want a simplified API for Java that mogt
> >> communicate info via an array of strings (or one formatted string).
> Sorry
> >> if that sounds out of left field.
> >> One AI said this:
> >> 2. Handle Java JNI Typemaps
> >> Because int** and object arrays (OSRSpatialReferenceShadow***) do not
> >> map cleanly to standard Java types, you must ensure your SWIG
> configuration
> >> or a companion helper helper translates them into manageable objects on
> the
> >> Java side.
> >> Alternatively, if dealing with direct pointer manipulation via SWIG
> >> typemaps is too complex, developers routinely implement a *custom C++
> >> wrapper function* inside osr.i that bundles the results into a string
> >> format (such as an array of matching EPSG strings and confidences)
> before
> >> passing it over the JNI boundary:
> >> swig
> >> %extend OSRSpatialReferenceShadow {
> >> // A simplified wrapper returning matches as formatted string
> arrays to avoid pointer hell
> >> char** FindMatchesSimple(char** options) {
> >> int nEntries = 0;
> >> int* panConfidence = NULL;
> >> OGRSpatialReferenceH* pahSRS =
> OGRSpatialReference_FindMatches(self, options, &nEntries, &panConfidence);
> >> char** papszResult = NULL;
> >> // Construct a structured string array containing
> "EPSG:Code,Confidence"
> >> for(int i = 0; i < nEntries; i++) {
> >> const char* pszAuthName =
> OGRSpatialReference_GetAttrValue(pahSRS[i], "AUTHORITY", 0);
> >> const char* pszAuthCode =
> OGRSpatialReference_GetAttrValue(pahSRS[i], "AUTHORITY", 1);
> >> // Format string logic, append to papszResult...
> >> // BDZ - TODO - NOTE - This is the real work needed to
> finish this method.
> >> OSRFreeSRSArray(pahSRS);
> >> CPLFree(panConfidence);
> >> return papszResult;
> >> On Thu, Aug 13, 2026 at 3:08?PM Barry DeZonia <bdezonia at gmail.com>
> wrote:
> >> I could maybe help here but, good god, it's been a long time since I've
> >> worked on the Java bindings and I remember almost nothing. Maybe if I
> >> inspect the Java bindings code I will remember some stuff. Naively, the
> >> function signature looks pretty simple to translate.
> >> On Thu, Aug 13, 2026 at 6:53?AM Even Rouault via gdal-dev <
> >> gdal-dev at lists.osgeo.org> wrote:
> >> Tom,
> >> yes FindMatches() is what is needed for your use case and it is not
> >> currently available in the Java bindings. That would require someone to
> >> write the appropriate typemap(s) to map the C types to Java types.
> >> Even
> >> Le 13/08/2026 ? 13:15, Tom Moore via gdal-dev a ?crit :
> >> Hi all,
> >> I'm running into a case where SpatialReference.AutoIdentifyEPSG() fails
> >> on a completely standard, well-formed ESRI-dialect .prj file, even
> though
> >> the underlying PROJ identification machinery (proj_identify(), as
> exercised
> >> via "projinfo --identify") resolves it correctly with 100% confidence.
> I'd
> >> like to know whether this is a known limitation, and whether there's a
> >> recommended workaround for Java bindings users specifically, since
> >> FindMatches() isn't exposed there.
> >> Environment:
> >> - GDAL 3.11.1 (Windows build)
> >> - PROJ 9.6.2
> >> - Java bindings (org.gdal.osr / SWIG)
> >> Input WKT (contents of a shapefile .prj, ESRI dialect):
> PROJCS["NAD_1983_UTM_Zone_11N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-117.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
> >> QGIS correctly identifies this as EPSG:26911.
> >> What I tried (Java):
> >> SpatialReference srs = new SpatialReference();
> >> srs.ImportFromESRI(lines); // also tried plain ImportFromWkt() but
> >> got the same result
> >> srs.SetAxisMappingStrategy(osrConstants.OAMS_TRADITIONAL_GIS_ORDER);
> >> try {
> >> srs.AutoIdentifyEPSG();
> >> } catch (Exception ex) {
> >> System.out.println("Exception: " + ex.getMessage());
> >> System.out.println("code = " + srs.GetAuthorityCode(null));
> >> Result:
> >> Exception: OGR Error: Unsupported SRS
> >> code = null
> >> gdal.GetLastErrorType() / GetLastErrorMsg() are empty. No additional
> >> diagnostic detail is surfaced beyond the generic exception.
> >> I ruled out several things before suspecting this is a
> AutoIdentifyEPSG()
> >> limitation rather than an environment/config issue on my end:
> >> 1. proj.db itself is correct. Confirmed by mounting the exact same
> >> proj.db (from the PROJ 9 data directory used by my JAva app) into a
> clean
> >> ghcr.io/osgeo/gdal:ubuntu-small-latest container and running
> >> `gdalsrsinfo -e` against the same .prj file. It resolved to EPSG:26911
> >> correctly, full WKT2 with all authority IDs.
> >> 2. PROJ_LIB / PROJ_DATA environment variables are set correctly and
> >> confirmed using System.getenv() to be visible to the process
> >> 3. Tried MorphFromESRI() (both via ImportFromESRI() alone, and combined
> >> with an explicit MorphFromESRI() call) - no change.
> >> 4. Tried explicit SetAxisMappingStrategy(OAMS_TRADITIONAL_GIS_ORDER)
> >> before calling AutoIdentifyEPSG() - no change.
> >> 5. Ran the projinfo.exe from the gdal build that I am using with the
> Java
> >> app directly against the same .prj file:
> >> projinfo.exe --identify fmu.prj
> >> Identification match count: 1
> >> EPSG:26911: 100 %
> >> So proj_identify() / FindMatches()-equivalent logic resolves this WKT
> >> perfectly in the exact same native build, but AutoIdentifyEPSG() fails
> on
> >> it.
> >> This looks consistent with a few things I found in the tracker/mailing
> >> list archives while investigating:
> >> - https://trac.osgeo.org/gdal/ticket/6188 -- maintainer comment noting
> >> AutoIdentifyEPSG() has "very limited capabilities" and would need fuzzy
> >> matching to handle inexact datum/ellipsoid names, "especially when
> dealing
> >> with WKT coming from ESRI."
> >> - https://github.com/OSGeo/gdal/issues/4038 -- near-identical repro WKT
> >> (ESRI-dialect UTM), with a maintainer noting AutoIdentifyEPSG() can
> return
> >> OGRERR_UNSUPPORTED_SRS while having still injected partial AUTHORITY
> tags
> >> into sub-nodes. This matches what I see when printing the WKT after the
> >> failed call (DATUM gets EPSG:6269, but the top-level PROJCS never gets
> >> an ID).
> >> - https://github.com/OSGeo/gdal/issues/2303 -- shows the standard
> Python
> >> workaround (fall back to FindMatches() when AutoIdentifyEPSG() fails),
> >> which leads to my second question below.
> >> Questions:
> >> 1. Is AutoIdentifyEPSG() failing on this ESRI-dialect NAD83/UTM WKT a
> >> known limitation, or does this look like a genuine regression/bug worth
> >> filing?
> >> 2. FindMatches() does not appear to be exposed in the Java SWIG bindings
> >> (org.gdal.osr.SpatialReference). Is that correct, or am I missing
> >> something? If it's genuinely absent, is there any appetite for adding
> it,
> >> given it's the documented fallback for exactly this situation in other
> >> language bindings?
> >> 3. Short of shelling out to "projinfo --identify" as a subprocess, is
> >> there a recommended in-process approach for Java bindings users to reach
> >> the same identification logic?
> >> Happy to provide a minimal reproducible test case / file a tracker issue
> >> if that's useful, but I wanted to check here first in case this is
> already
> >> understood behavior.
> >> Thanks,
> >> Tom
> >> _______________________________________________
> >> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://
> >> -- http://www.spatialys.com
> >> My software is free, but my time generally not.
> >> LLMs contribute to global warming and brain rot.
> >> Let's guillotine them! "Ah ! ?a ira, ?a ira, ?a ira !"
> >> Tom Moore
> >> Spatial Planning Systems
> >> 960 Burkes Bluff Lane
> >> Deep River ON K0J 1P0
> >> Canada
> >> Phone: +1 613 584 9354
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260813/1850b865/attachment.htm
> Subject: Digest Footer
> End of gdal-dev Digest, Vol 267, Issue 6
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260818/cae66829/attachment-0001.htm>
