[gdal-dev] FLIR thermal with embedded image
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Feb 2 09:39:34 PST 2026
Hi Even
I was not able to achieve that, sorry. So finally I made the PR with an
original image.
If anybody has one image that works I can still replace mine.
Thanks
On Sat, 31 Jan 2026 at 03:20, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> What about the hard core GDAL contributor way of starting with a small
> JPEG image and then adding the needed bytes with your favorite hexadecimal
> editor :-) ?
> Otherwise, still a bit of use of your hexadecimal editor, but just to find
> out a couple offfset/lenghts, you may try the trick of starting from an
> existing file, keeping the begin in a part, the end in the other part, and
> omitting most of the embedded image using a /vsisparse/ .XML file and
> replacing it with a <ConstantRegion> at zero. Like
> https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/data/grib/rotated_pole.grb2.xml
>  and then you use "/vsisparse/your.xml" as a valid JPEG dataset name.
> Or variation of the above, perhaps a bit less convoluted, start with your
> initial image, set to the zero byte unneeded ranges, and zip it.
> Even
> Le 30/01/2026 à 10:43, Javier Jimenez Shaw via gdal-dev a écrit :
> Hi
> TL;DR: I need a "small" FLIR image file for a unit test in GDAL. Do you
> have one?
> I am working on GDAL's thermal jpeg code, to read an embedded RGB image
> that some FLIR cameras are including inside the JPEG, in addition to the
> thermal information/image.
> I want to add a unit test with a real image, but unfortunately I only have
> "big" images, around 4 or 5 MB.
> It would be great if anybody has a smaller image that can be included in
> the GDAL tests code (with the copyright/license permissions that it has).
> The model "FLIR T640" I think produces images of about 1.5 MB only. But it
> can be other models as well.
> To check if it has the Embedded Image, just run this:
> If you see any output, please contact me.
> Thank you!
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260202/0cb26ab4/attachment.htm>
