[gdal-dev] [PROPOSAL] Add CADRG write support via RPFTOC/NITF drivers
Even Rouault
even.rouault at spatialys.com
Wed Feb 18 06:17:56 PST 2026
as an update of that thread, the below plan has now come true per
https://github.com/OSGeo/gdal/pull/13940
Even
Le 11/06/2025 à 14:51, Patrik Sylve via gdal-dev a écrit :
> Hi,
> We are exploring the possibility of adding write support for CADRG
> format in GDAL and would appreciate some community feedback before
> starting implementation.
> There is currently no open-source workflow for creating CADRG. GDAL
> can already read CADRG via RPFTOC/NITF drivers, so extending that work
> feels like a good next step.
> Short background on CADRG format:
> CADRG is a Raster Product Format (RPF) that consists of a TOC file
> referencing data frames. Each data frame is stored as a National
> Imagery Transmission Format (NITF) message.
> GDAL currently supports:
> * Reading CADRG (a.toc) via the RPFTOC driver
> * Reading individual CADRG frames via the NITF driver
> * Writing NITF images, both without and with JPEG compression
> To implement a CADRG writer, we could extend the existing NITF and
> RPFTOC drivers:
> NITF:
> * Implement Vector Quantisation compression
> * Add option to set Frame size
> ** A CADRG frame must be 1536x1536 pixels, so output would be tiled
> * Add option to set CADRG scale
> RPFTOC:
> * Extend with 'write' mode
> ** Internally call NITF driver to generate CADRG compliant data frames
> ** Generate a .toc file per MIL-STD-2411
> Example usage, create a CADRG from a TIF-file:
> gdal_translate input.tif ./RPF \
> -of RPFTOC \
> -co "PRODUCT=CADRG" \
> * # NITF file header options*
> -co "FTITLE=My CADRG Product" \
> -co "FSCLAS=U" \
> Output:
> └── RPF/
> ├─── a.toc
> └─── frames/
> ├──── 00AVL01C.TL6
> └──── 00AVM01C.TL6
> Drivers:
> * https://gdal.org/en/stable/drivers/raster/rpftoc.html
> * https://gdal.org/en/stable/drivers/raster/nitf.html
> Standards:
> * CADRG:
> http://everyspec.com/MIL-PRF/MIL-PRF-080000-99999/MIL-PRF-89038_25371/
> * RPF: http://everyspec.com/MIL-STD/MIL-STD-2000-2999/MIL-STD-2411_6903/
> Would this be a welcomed addition? Any thoughts or feedback is
> appreciated.
> Best regards / Vänliga hälsningar
> *Patrik Sylve*
> Software Developer
> *E:***patrik.sylve at t-kartor.com
> www.t-kartor.com <http://www.t-kartor.com/>
> /This e-mail is private and confidential between the sender and the
> addressee. In the event of misdirection, the recipient/
> /is prohibited from using, copying or disseminating it or any
> information in it. Please notify the above of any such misdirection./
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260218/0a5c2207/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260218/0a5c2207/attachment-0001.png>
