[gdal-dev] gdal vector convert, should --output-layer be required with CSV?
Scott public at postholer.com
Sat Feb 21 11:32:10 PST 2026
src.csv and dst.csv are identical, containing:
lon,lat,desc
-123,90,"some other stuff"
then run:
gdal vector convert -i src.csv -o dst.csv --append
ERROR 1: Attempt to create csv layer (file) against a non-directory
datasource.
ERROR 1: Failed to write layer 'src'. Use --skip-errors to ignore errors
and continue writing.
but the following works:
gdal vector convert -i src.csv -o dst.csv --append --output-layer dst
Should --output-layer be required with CSV?
The same happens if source is a single layer .gpkg.
Thanks!
Scott
www.postholer.com
