[gdal-dev] New build warning
Even Rouault
even.rouault at spatialys.com
Mon Jan 5 09:51:44 PST 2026
Our Mac instances must use the Apple-provided compiler I suppose. We
also have a Linux CI config using a recent clang (from Fedora:rawhide,
so cutting edge)
OpenMP detection is done through the CMake provided FindOpenMP module:
https://cmake.org/cmake/help/latest/module/FindOpenMP.html
But I would expect your compiler to support it although it is not
cutting edge.
You can explicitly disable it by setting -DGDAL_USE_OPENMP=OFF
Le 05/01/2026 à 18:41, Andrew Bell a écrit :
> Hi,
> It looks like CI is way ahead of my config. Are you using an
> Apple-provided compiler or one from clang or elsewhere?
> [sd-integration] (gdal) $ clang++ --version
> Apple clang version 14.0.3 (clang-1403.0.22.14.1)
> Target: x86_64-apple-darwin22.5.0
> Thread model: posix
> InstalledDir:
> /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin
> On Mon, Jan 5, 2026 at 12:32 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
> Hi Andrew,
> openmp is enabled when available since
> https://github.com/OSGeo/gdal/commit/2a3f06b90f2d68da446451a44090aa38fd6f4b5a#diff-c6d7b93ff4bf010c2c6218c9329af9afb9a00aab7871175046a9b50f26826452R435
> . What is your clang version ? That warning are not shown on our
> clang based CI configurations up to now.
> Even
> Le 05/01/2026 à 18:25, Andrew Bell via gdal-dev a écrit :
>> Hi,
>> I updated to the latest master and am now seeing the following
>> warning during compilation:
>> [156/1486] Building CXX object
>> alg/CMakeFiles/alg.dir/thinplatespline.cpp.o
>> clang: warning: argument unused during compilation: '-Xclang
>> -fopenmp' [-Wunused-command-line-argument]
>> If anyone has some info on this, please let me know.
>> Andrew Bell
>> andrew.bell.ia at gmail.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
> Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260105/c17a2295/attachment-0001.htm>
