[gdal-dev] Decoding feature blobs and tracking FIDs in MVT datasets
Even Rouault even.rouault at spatialys.com
Fri Jan 9 17:09:27 PST 2026
Hi Linda,
Happy New Year
> I’ve put together a short document with the planned implementations
> [0]. Could you please take a look (or anyone else interested in this
> topic) and let me know if this seems okay to implement? Part of the
> work I have already done, but I’d like to make sure it follows GDAL
> conventions all the way through.
I've read your detailed document. Your plan looks solid. My main remark
is that when a driver accepts to open a dataset in GDAL_OF_UPDATE mode,
it is expected that read operations are still available. Failing to do
that could cause issues for users/software that always open in update
mode if possible, even if they end up not doing any change. By using
OGRMVTWriterDataset which is write-only, you wouldn't be able to meet
that expectation. It could be complicated to extend OGRMVTWriterDataset
to have read capabilities (especially since the writing side generates
several zoom levels at once, whereas the reading side has one dataset
per zoom level), so I would suggest that the update mode you describe is
triggered by both GDAL_OF_UPDATE and a specific open option like
EDIT_ONLY=YES / UPDATE_ONLY=YES. Or maybe just the later.
If you plan to implement updates of existing features, implementing
ISetFeature() only would be sufficient. IUpdateFeature() is reserved for
drivers that can offer such capability naturally, typically drivers for
a SQL database.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260110/a26e263b/attachment.htm>
