[gdal-dev] Support for Terrain-RGB
Lars Ahlzen
lars at ahlzen.com
Mon Jan 12 05:35:08 PST 2026
I think either "rgb-dem" or "encode-rgb" could work. While not strictly
limited to RGB or DEMs, at least that's their typical and intended use.
Sounds like a raster driver, rather than a new raster DEM mode, would be
advantageous. I imagine creation options might include:
- OFFSET (or BASE, as known in the terrain-RGB spec)
Defaults to -10000
- SCALE (or maybe STEP, to not to confuse it with any required scaling
of the input?)
Defaults to 0.1
- DRIVER
Raster driver to output encoded image, e.g. PNG, WEBP, GTiff. Inferred
from the output extension if omitted.
- BANDS
Order of raster bands to encode values into, most significant first.
E.g. "RGB", "RGBA", "BGR", "RG".
Defaults to "RGB". If A is not included in the bands, the A channel can
be used for alpha.
For ease of use, perhaps an ENCODING option (or similar) could provide
preset values for the above, such as:
--co ENCODING=TERRAIN_RGB
would be equivalent to
--co OFFSET=-1000 --co SCALE=0.1 --co BANDS=RGB
-co ENCODING=TERRARIUM
--co OFFSET=-32768 --co SCALE=0.00390625 --co BANDS=RGB
This driver would allow things like:
gdal raster convert dem.tif rgb.png --of encode-rgb --co DRIVER=PNG
--co ENCODING=TERRARIUM
--co BANDS=RGB --co OFFSET=-10000 --co SCALE=0.1
--co BANDS=BG --co OFFSET=-1000 --co SCALE=1
gdal raster tile --min-zoom 5 --max-zoom 15 --format ENCODE_RGB --co
DRIVER=PNG --co ENCODING=TERRARIUM dem.tif rgb-tiles/
DRIVER=WEBP --co LOSSLESS=YES --co BANDS=RGB --co OFFSET=-10000 --co
SCALE=0.1 dem.tif rgb-tiles/
Certain creation options, like LOSSLESS=YES in the last example, may
need to be passed on from the ENCODE_RGB driver to the actual output
driver. Is that possible in general, or would it have to be handled as
special cases for different formats?
- Lars
On 09/01/2026 07:02, Andrey VI via gdal-dev wrote:
> Why not just "rgb-dem", i.e. "RGB encoded DEM"?
> Friday, January 9, 2026 3:16 AM +03:00 from rayg via gdal-dev
> <gdal-dev at lists.osgeo.org>:
> Maybe call it "scalar-rgb"? Because ultimately what the encoding
> does is use the color channels to hold a single value. It doesn't
> even have to be for elevations at all.
> Could also add swizzle options in case BGR or some other order is
> used. And include the alpha channel just in case, but also let
> alpha be alpha if needed. If e.g. "A" is left off from the swizzle
> option, then it's an actual alpha channel.
> More general would be scalar encoding of any multichannel
> (multiband) file, e.g. YCbCr, HSV, CMYK, etc.
> Ray
> On Thu, 8 Jan 2026 at 1:13 PM Even wrote:
> > There's nothing especially terrain (or topography) about this afaics,
> > and utility seems like the right approach rather than creating a
> > format variant.
> Actually Frédéric's intersting remark abou potential usage with "gdal
> raster tile" would actually make the driver approach a better
> choice.... unless we would extend "gdal raster tile" to accept a
> pipeline to go to create a final tile from a 'raw' one, like 'gdal
> raster tile --tile-pipeline="read ! encode-rgb --offset=-10000 ! write
> --of PNG" --extension png in.tif out_directory' .
> But a ENCODE_RGB driver approach is more simple than implementing that.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Andrey
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260112/de48c186/attachment-0001.htm>
