[gdal-dev] Support for Terrain-RGB
Even Rouault even.rouault at spatialys.com
Mon Jan 12 09:15:12 PST 2026
> That's probably the way to go. The last example would then be:
> gdal raster tile --min-zoom 5 --max-zoom 15 --format ENCODE_RGB --co
> DRIVER=WEBP --co DRV_OPT_LOSSLESS=YES --co BANDS=RGB --co
> OFFSET=-10000 --co SCALE=0.1 dem.tif rgb-tiles/
> I can start looking at implementing such a driver. I assume this would
> warrant an RFC?
Your call, but RFCs are generally used for changes with wide impact in
the code base. Drivers have generally a localized impact, particularly
here when they don't introduce new external dependencies. You could also
for example create a ticket with details of your plan if you want to
discuss them before starting the coding .
http://www.spatialys.com
