[gdal-dev] Odd issue with parquet using gdal python opening inside Django code
Michael Smith
michael.smith.erdc at gmail.com
Tue Jan 13 16:03:25 PST 2026
We use gdal with Django and build gdal from conda and install the parquet driver that way. But we have just found an odd issue when a parquet file is opened in our Django code vs in a Django shell.
In the shell we get
gf = gdal.OpenEx('/tmp/stac_48069_usgs-3dep_rasters.parquet')
GDAL: On-demand registering /home/gridusr/gridpixi/.pixi/envs/default/lib/gdalplugins/ogr_Parquet.so using RegisterOGRParquet.
GDAL: GDALOpen(/tmp/stac_48069_usgs-3dep_rasters.parquet, this=0x5626a2e395a0) succeeds as Parquet.
PARQUET: Compression (of first column): zstd
ARROW: Memory pool: bytes_allocated = 0
ARROW: Memory pool: max_memory = 0
GDAL: GDALClose(/vsis3/grid-dev-publiclidar/stac/testgrid/rasters/stac_48069_usgs-3dep_rasters.parquet, this=0x5626a2e38990)
And everything works fine
In the code we get
GDAL: GDALOpen(/tmp/stac_48069_usgs-3dep_rasters.parquet, this=0x7f43945696b0) succeeds as Parquet.
PARQUET: Dealing with field GEOMETRY of extension type geoarrow.polygon as list<rings: list<vertices: struct<x: double not null, y: double not null> not null> not null>
GDAL: GDALOpen(/tmp/stac_48069_usgs-3dep_rasters.parquet, this=0x7f43945d6760) succeeds as Parquet.
OGR: GetLayerCount() = 1
And this line seems to be the issue
In this case, the geometry is not recognized.
Calling gdal.VectorInfo(gf) I see
INFO: Open of `/tmp/stac_48069_usgs-3dep_rasters.parquet'
using driver `Parquet' successful.
Layer name: stac_48069_usgs-3dep_rasters
Geometry: None
Feature Count: 109314
Layer SRS WKT:
(unknown)
GEOMETRY: String(JSON) (0.0)
In the django python shell we get
In [7]: print (res)
Geometry: Polygon
Extent: (-179.001667, -15.001667) - (180.000000, 84.001667)
Layer SRS WKT:
(unknown)
Geometry Column = GEOMETRY
Any ideas?
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
