[gdal-dev] Odd issue with parquet using gdal python opening inside Django code
Even Rouault even.rouault at spatialys.com
Tue Jan 13 17:43:45 PST 2026
> My hypothesis would be that in the Django context something registers
> the geoarrow.polygon extension to libarrow (pyarrow maybe). That said
> the Parquet driver is supposed to be robust to that, so there must be
> some subtelty.
Actually it was not robust :-) Will be fixed per
https://github.com/OSGeo/gdal/pull/13697
Even
http://www.spatialys.com
