[gdal-dev] Reading from (geo)parquet using mixed spatia and non-spatiall filters
Ari Jolma
ari.jolma at gmail.com
Thu Jan 22 03:49:56 PST 2026
Thanks for the replies. I'm progressing but now I hit something I don't
understand.
I have a large GPKG file which I converted into a Parquet file. If I now
do a simple layer.GetFeature(fid) on a random fid on the layer, the
feature is retrieved from GPKG really fast (also if the file is in S3)
but from Parquet it is slow (~ 20 secs) even on local filesystem.
On both files layer.GetFIDColumn() reports "fid". There is a native "ID"
column on the GPKG but fid <> ID.
I used ogr2ogr to create the Parquet file. I had -lco COMPRESSION=None
Ari
Michael Smith kirjoitti 18.1.2026 klo 18.09:
> I combine attribute and spatial filters a lot on large parquet files using a combination of SetSpatialFilter() and SetAttributeFilter() before querying. I've only had some issues with partition elimination which have now been fixed. Sometimes the ADBC connection can be faster to query but opening the file with gdal.OpenEx() is slower. And ADBC takes more memory. I find the gdal query method generally better.
> Having access to the sql functions of duckdb is the only reason I ever use ADBC.
> Mike
