[gdal-dev] gdal.Run not taking arguments
Even Rouault
even.rouault at spatialys.com
Fri Jan 30 18:09:36 PST 2026
Mike,
not sure why that fails for you, but works for me:
>>> gdal.Run("vector", "edit", input='poly.gpkg', output='out.parquet',
crs="EPSG:4326", overwrite=True, creation_option={"compression": "zstd"})
<osgeo.gdal.Algorithm; proxy of <Swig Object of type 'GDALAlgorithmHS *'
at 0x7f5feceafe30> >
Even
Le 30/01/2026 à 18:35, Michael Smith via gdal-dev a écrit :
> Trying to run a gdal cli using the Run command. I am passing the arguments as keyword arguments but its not being taken.
> _ = gdal.Run("vector", "edit",
> input=stac_file,
> output=final_stac_file,
> crs="EPSG:4326",
> overwrite=True,
> The input and output are working but the remaining arguments are not. Also tried passing as a dict argument.
> I've used this with other commands successfully (and it does work properly at the command line).
> Not sure what I'm doing wrong.
> Mike
http://www.spatialys.com
