[gdal-dev] FLIR thermal with embedded image
Even Rouault even.rouault at spatialys.com
Fri Jan 30 18:20:02 PST 2026
Javier,
What about the hard core GDAL contributor way of starting with a small
JPEG image and then adding the needed bytes with your favorite
hexadecimal editor :-) ?
Otherwise, still a bit of use of your hexadecimal editor, but just to
find out a couple offfset/lenghts, you may try the trick of starting
from an existing file, keeping the begin in a part, the end in the other
part, and omitting most of the embedded image using a /vsisparse/ .XML
file and replacing it with a <ConstantRegion> at zero. Like
https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/data/grib/rotated_pole.grb2.xml
  and then you use "/vsisparse/your.xml" as a valid JPEG dataset name.
Or variation of the above, perhaps a bit less convoluted, start with
your initial image, set to the zero byte unneeded ranges, and zip it.
Even
Le 30/01/2026 à 10:43, Javier Jimenez Shaw via gdal-dev a écrit :
> Hi
> TL;DR: I need a "small" FLIR image file for a unit test in GDAL. Do
> you have one?
> I am working on GDAL's thermal jpeg code, to read an embedded RGB
> image that some FLIR cameras are including inside the JPEG, in
> addition to the thermal information/image.
> I want to add a unit test with a real image, but unfortunately I only
> have "big" images, around 4 or 5 MB.
> It would be great if anybody has a smaller image that can be included
> in the GDAL tests code (with the copyright/license permissions that it
> has).
> The model "FLIR T640" I think produces images of about 1.5 MB only.
> But it can be other models as well.
> To check if it has the Embedded Image, just run this:
> If you see any output, please contact me.
> Thank you!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260131/0015b37a/attachment.htm>
