[gdal-dev] VRT File Support Within a Zstd-Compressed Zip
Jordan Dauble Jordan.Dauble at SimBlocks.io
Sun Jul 19 14:17:10 PDT 2026
Good afternoon, I would like to request that a new feature be added to GDAL. Our team has found that while both libzip and GDAL support Zstd compression, the support does not extend to loading vrt files within a Zstd-compressed zip. We have a use case where the vsizip file handler is used on a Zstd-compressed zip, such as
ogr2ogr outputTest.gpkg /vsizip/{<zip_filename>}/extent.geojson.
We believe the following files would require modification to support this feature:
port/cpl_minizip_unzip.cpp
port/cpl_vsil_gzip.cpp
Jordan Dauble
SimBlocks LLC, Founder & CEO
407-641-5218
253 Plaza Dr., Ste C
Oviedo, FL 32765
https://www.simblocks.io/
Chair, SISO CIGI PSG<https://www.sisostandards.org/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260719/a9816854/attachment.htm>
