[gdal-dev] Optional rust library as a dependency of the Zarr driver
Even Rouault
even.rouault at spatialys.com
Thu Jun 11 17:34:02 PDT 2026
> Yes, I know there might be checksums, but I think it's still a problem.
As you've noticed by carefully reviewing the PR 😜 , it uses sha1sum to
identify tags
> I think a good example is librsvg. It's a library, written significantl
> in rust, but programs that use it just look for a .h and link against
> it. They aren't forced to act like it's all special because it used
> rust.
As you've noticed, my PR offers that possibility if someone packages
cpcodec and installs pcodec.h and libpcodec.so
> Is pcodec packaged in Debian or any place else?
Not that I'm aware of
> Deoes gdal have a prior history of dealing with dependencies that should
> be packaged but aren't?
yes and no. We have a few vendored ones
> I wonder if the plugin system is the answer here, to say that anything
> with troublesome (not packaged and checkable with cmake without special
> help) dependencies should be a plugin maintained in a separate repo.
The Zarr driver itself can be built as a plugin. But a plugin of a
plugin, that's unknown territory
Anyway if you or anyone else doesn't like it, GDAL_USE_PCODEC=NO will be
your friend, and/or not having git or cargo in your build env.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260612/9872ab06/attachment.htm>
