[gdal-dev] Python bindings: aliasing gdal.Open and gdal.OpenEx
Even Rouault
even.rouault at spatialys.com
Fri Jun 19 06:50:44 PDT 2026
Hi Vincent,
Positive feedback is also appreciated :-)
Even
Le 19/06/2026 à 10:13, Vincent Schut via gdal-dev a écrit :
> On 2026-06-17 1:49 pm, Even Rouault via gdal-dev wrote:
>> Hi,
>> I'd like to have a broader feedback of the community on
>> https://github.com/OSGeo/gdal/pull/14763 . Please read it in detail.
>> In practice, the main backwards incompatibility would be the point 1
>> I mention in the PR text, that is that for current users of
>> gdal.Open(dsname), they would now get vector datasets opened in
>> addition to raster ones. While I see this is as a long term benefit,
>> at least one user (https://github.com/ubarsc/rios/pull/192) had to
>> work around it since they expected gdal.Open() to fail on vector
>> datasets. The workaround being to use gdal.OpenEx(dsname,
>> gdal.OF_RASTER) that will work before and after the PR, or if
>> targeting only post PR state, gdal.Open(dsname, gdal.OF_RASTER)
>> PR 14763 would be potential material for a GDAL 4 if that did occur,
>> but I don't know if it is desirable and even if it was, I don't think
>> it would happen in a short or medium term (mostly because the GDAL
>> dev community is too small to be able to gather a significant set of
>> backwards incompatible change in a reasonable period of time, while
>> not blocking features to be released at a reasonable frequency). So
>> we're more in a situation where we land a few backwards incompatible
>> change each (non bugfix) release.
>> Even
> Hi Even,
> (I doubted whether to reply because it was a bit unclear to me if you
> only wanted people with concerns to reply, or also people who don't
> see any issue with the proposed change.)
> We (as quite heavy users of gdal in our internal python software) do
> not see any issues with this proposal for us, and would in fact
> welcome this change because it will reduce ambiguity between the 2
> possible ways to open raster datasets.
> Thanks for asking feedback,
> Vincent.
> Vincent Schut
> Remote Sensing Software Engineer
> +31 302272679 ~ Maliebaan 22 | 3581CP | Utrecht | Netherlands
> Linkedin <https://www.linkedin.com/company/satelligence/>~
> satelligence.com
> <http://www.satelligence.com><http://www.satelligence.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260619/c2ca8271/attachment-0001.htm>
