[gdal-dev] confused about coordinate dimension
Daniel Baston dbaston at gmail.com
Mon Jun 29 11:57:58 PDT 2026
Hi Rich,
I'm sure there's a historical reason for this, but it looks like GDAL has
two very similar methods: GetCoordinateDimension() and
CoordinateDimension(). The former, rather surprisingly, returns only 2 or
3. The latter one returns the value you're looking for:
>>> from osgeo import ogr
>>> g = ogr.CreateGeometryFromWkt('POINT ZM (1 2 3 4)')
>>> g.CoordinateDimension()
4
>>> g.GetCoordinateDimension()
3
Dan
On Mon, Jun 29, 2026 at 2:45 PM Richard Greenwood via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> In Python, I want to find the coordinate dimension of my source. For
> example, with a postgis table with geometry(MultiLineStringZM,4326). My
> Python:
> in_lyr = in_ds.ExecuteSQL(select)
> feature0 = in_lyr.GetNextFeature()
> feature0_geom = feature0.GetGeometryRef()
> feature0_geom.GetGeometryType()        # 3005
> ogr.GeometryTypeToName(3005)            #  '3D Measured Multi Line String'
> feature0_geom.GetCoordinateDimension()  # 3
> Based on:
> https://gdal.org/en/stable/api/vector_c_api.html#_CPPv425OGR_G_CoordinateDimension12OGRGeometryH
> I am expecting the coordinate dimension to be 4. Am I approaching this
> incorrectly?
> Richard W. Greenwood
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260629/f08d9ac1/attachment.htm>
