[gdal-dev] optimizing GTI performance (follow-up on #14063)
Vincent Schut schut at satelligence.com
Mon Mar 16 08:58:13 PDT 2026
This is a follow-up on https://github.com/OSGeo/gdal/issues/14063.
I decided to take it to the list instead, because I'm not sure whether
this is an issue or simply a discussion on performance. (Let me know if
you rather take this to gh issues again; happy to do so).
Please read the original issue first, to avoid wasting time on questions
that were already answered there :-)
Short context: trying to get good performance out of a GTI mosaic which
wraps (potentially a lot of) remote tifs (on AWS S3). The tifs are in
UTM, the mosaic is reprojecting to epgs:4326.
After the performance optimizations made by Even as response to #14063
(https://github.com/OSGeo/gdal/pull/14089 and
https://github.com/OSGeo/gdal/pull/14094), I did some testing. The
results were rather... confusing.
All these tests were done with a fresh gdal master build (GDAL
3.13.0dev-28b33d81c7, released 2026/03/15).
What I expected (hoped):
- wrapping a (single) remote tif with a GTI should not affect
performance too much
- gdal_translate to have better or similar performance on the GTI than
gdalwarp, especially with using -oo WARPING_MEMORY_SIZE. As Even said,
using gdalwarp means the warping logic is used twice, where it is only
needed once. Using gdal_translate should therefore show better performance.
What I found:
- gdalwarp on the GTI is about 50% slower than on the remote tiff
directly (but maybe that is simply the cost of having a GTI wrapper? I
hoped it would be less)
- gdal_translate is still waaay slower (10x) than gdal_warp. Using
WARPING_MEMORY_SIZE hardly seems to make a difference.
- this is only/mainly when targeting remote tifs. When using local
files, the timings are very different. But: the remote case is the case
we need, and what want to optimize. So I focus on that.
My tests were on a 22-core (according to "nproc") machine, 64G ram.
Results will probably vary with number of cores, network speed, physical
location (I'm in Europe, these tifs are probably in a bucket in the US),
and also the size of the block extracted. All tests below extract the
same 0.2 degree block.
These are the commands I ran as test:
# export config options
export GDAL_CACHEMAX=1GB GDAL_NUM_THREADS=ALL_CPUS
DISABLE_READDIR_ON_OPEN=EMPTY_DIR
CPL_VSIL_CURL_ALLOWED_EXTENSIONS="tiff" AWS_NO_SIGN_REQUEST=YES
# create a GTI wrapping 1 remote tif
gdal driver gti create --resolution 0.00006,0.00006 --ot Int8
--band-count 64 --nodata -128 --dst-crs epsg:4326 --of gpkg
/vsis3/us-west-2.opendata.source.coop/tge-labs/aef/v1/annual/2024/30N/xpzba7dllw4la2007-0000008192-0000000000.tiff
test_1tiff.gti.gpkg
# start of tests
# each test extracts the same 0.2 x 0.2 degree block.
# gdal_warp on the remote tif directly, doing the exact same
reprojecting as the GTI is doing
gdalwarp -overwrite -te -5.8 5.6 -5.6 5.8 -tr 0.00006 -0.00006 -t_srs
epsg:4326 -wm 1G  -co tiled=yes -co blockxsize=512 -co blockysize=512
-co interleave=band
result_tiff_allbands.tif
# time: 0m33s
# gdalwarp on the GTI which wraps the same tif
gdalwarp -overwrite -te -5.8 5.6 -5.6 5.8 -wm 1G  -co tiled=yes -co
blockxsize=512 -co blockysize=512 -co interleave=band
test_1tiff.gti.gpkg result_gti_allbands.tif
# time: 0m47s
# gdal_translate on the GTI with -oo WARPING_MEMORY_SIZE set to 1G
gdal_translate -oo WARPING_MEMORY_SIZE=1GB -projwin -5.8 5.8 -5.6 5.6
-co tiled=yes -co blockxsize=512 -co blockysize=512 -co interleave=band
test_1tiff.gti.gpkg gt_result_gti_allbands.tif
# time: 5m31s
# gdal_translate on the GTI without the -oo WARPING_MEMORY_SIZE option
gdal_translate -projwin -5.8 5.8 -5.6 5.6 -co tiled=yes -co
# time: 5m16s
Vincent Schut
Remote Sensing Software Engineer
+31 302272679 ~ Maliebaan 22 | 3581CP | Utrecht | Netherlands
Linkedin <https://www.linkedin.com/company/satelligence/>~
satelligence.com <http://www.satelligence.com><http://www.satelligence.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260316/6a818305/attachment-0001.htm>
