[gdal-dev] WFS-T Transaction serializes Date/DateTime fields in non-ISO format
Even Rouault even.rouault at spatialys.com
Thu Mar 19 08:21:10 PDT 2026
Fix queued in https://github.com/OSGeo/gdal/pull/14182
Le 19/03/2026 à 13:36, Denis Rykov via gdal-dev a écrit :
> Hi,
> I've found that GDAL 3.12.1 serializes Date and DateTime fields
> incorrectly in WFS-T Transaction requests — using / as date separators
> and a space instead of T between date and time components. This is not
> compliant with W3C XML Schema Part 2, which defines the formats
> required by OGC WFS: YYYY-MM-DD and YYYY-MM-DDTHH:MM:SSZ.
> A similar issue was previously fixed in the GML driver:
> https://github.com/OSGeo/gdal/issues/2897 - should the same fix be
> applied to the WFS-T writer?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
