[gdal-dev] GDAL 3.13.0 release candidate available
Greg Troxel
gdt at lexort.com
Mon May 4 14:17:07 PDT 2026
Thanks for confirming the packing list changes are expected.
Jukka: gdal 3.13.0rc1 geojson does have newlines.
With RC1 (yes I know RC2 was announced just now, will update and
retest), I found that pdal-lib did not build, but I had old pdal-lib
(2.8.4!), and have updated to the latest release (2.10.1), and that's
fine.
Then, building qgis 3.44.9 (current LTR, and really, most recent code
that can be viewed as stable) fails, and I think it's due to a type
change in GDAL. Sending this sooner rather than later - I wonder how
building qgis 3.44.9 is going for other people on other platforms.
(omitting earlier part of log, NetBSD 10 amd64)
[301/5656] Building CXX object src/core/CMakeFiles/qgis_core.dir/providers/ogr/qgsogrproviderconnection.cpp.o
FAILED: [code=1] src/core/CMakeFiles/qgis_core.dir/providers/ogr/qgsogrproviderconnection.cpp.o
/tmp/work/geography/qgis/work/.cwrapper/bin/c++ -DCMAKE_SOURCE_DIR=\"/tmp/work/geography/qgis/work/qgis-3.44.9\" -DPROTOBUF_USE_DLLS -DQT_CONCURRENT_LIB -DQT_CORE_LIB -DQT_DBUS_LIB -DQT_DISABLE_DEPRECATED_BEFORE=0x050800 -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_NO_CAST_TO_ASCII -DQT_NO_DEBUG -DQT_NO_FOREACH -DQT_POSITIONING_LIB -DQT_PRINTSUPPORT_LIB -DQT_SERIALPORT_LIB -DQT_SQL_LIB -DQT_SVG_LIB -DQT_USE_QSTRINGBUILDER -DQT_WIDGETS_LIB -DQT_XML_LIB -DSIP_VERSION=0x060f03 -DTEST_DATA_DIR=\"/tmp/work/geography/qgis/work/qgis-3.44.9/tests/testdata\" -DWITH_COPC -DWITH_EPT -D_HAVE_PTHREAD_ -Dqgis_core_EXPORTS -I/tmp/work/geography/qgis/work/qgis-3.44.9/cmake-pkgsrc-build/src/core/qgis_core_autogen/include -I/tmp/work/geography/qgis/work/qgis-3.44.9/cmake-pkgsrc-build -I/tmp/work/geography/qgis/work/qgis-3.44.9/external/poly2tri -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/ept -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/copc -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/vpc -I/tmp/work/geography/qgis/work/qgis-3.44.9/cmake-pkgsrc-build/src/core -I/tmp/work/geography/qgis/work/qgis-3.44.9/external/meshOptimizer -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/3d -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/actions -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/annotations -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/auth -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/browser -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/callouts -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/classification -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/diagram -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/dxf -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/editform -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/effects -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/elevation -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/expression -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/externalstorage -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/fieldformatter -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/geometry -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/geocoding -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/gps -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/labeling -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/labeling/rules -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/layertree -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/layout -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/locator -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/maprenderer -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/mesh -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/metadata -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/network -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/numericformats -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/painting -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/pal -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/pdf -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/plot -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/pointcloud -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/pointcloud/expression -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/processing -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/processing/models -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/proj -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/project -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/arcgis -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/memory -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/gdal -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/ogr -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/meshmemory -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/sensorthings -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/raster -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/renderer -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/scalebar -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/settings -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/sensor -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/stac -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/symbology -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/textrenderer -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/tiledscene -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/validity -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/vector -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/vectortile -I/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/web -I/tmp/work/geography/qgis/work/qgis-3.44.9/external -I/tmp/work/geography/qgis/work/qgis-3.44.9/external/delaunator-cpp -I/tmp/work/geography/qgis/work/qgis-3.44.9/external/kdbush/include -I/tmp/work/geography/qgis/work/qgis-3.44.9/external/nmea -I/tmp/work/geography/qgis/work/qgis-3.44.9/external/rtree/include -I/tmp/work/geography/qgis/work/qgis-3.44.9/external/tinygltf -isystem /tmp/work/geography/qgis/work/.buildlink/include -isystem /usr/pkg/qt5/include/Qca-qt5/QtCrypto -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtCore -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/./mkspecs/netbsd-g++ -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtGui -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtXml -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtWidgets -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtSvg -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtNetwork -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtSql -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtConcurrent -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtPositioning -isystem /tmp/work/geography/qgis/work/.buildlink/include/geos -isystem /usr/pkg/qt5/include -isystem /usr/pkg/qt5/include/QtDBus -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtPrintSupport -isystem /usr/pkg/include -isystem /tmp/work/geography/qgis/work/.buildlink/qt5/include/QtSerialPort -O2 -I/usr/pkg/include -I/usr/include -I/usr/pkg/include/python3.13 -Dz_off_t=long -I/usr/pkg/include/libxml2 -I/usr/pkg/include/minizip -I/usr/pkg/qt5/include -I/usr/pkg/include/glib-2.0 -I/usr/pkg/include/gio-unix-2.0 -I/usr/pkg/lib/glib-2.0/include -I/usr/pkg/include/harfbuzz -I/usr/pkg/include/freetype2 -I/usr/X11R7/include -I/usr/X11R7/include/libdrm -I/usr/pkg/include/gstreamer-1.0 -I/usr/pkg/qwt-6.3.0/include -Wall -Wextra -Wno-long-long -Wformat-security -Wno-strict-aliasing -Wnon-virtual-dtor -Wno-redundant-move -Wno-misleading-indentation -Wno-deprecated-copy -std=gnu++17 -fPIC -fvisibility=hidden -fPIC -MD -MT src/core/CMakeFiles/qgis_core.dir/providers/ogr/qgsogrproviderconnection.cpp.o -MF src/core/CMakeFiles/qgis_core.dir/providers/ogr/qgsogrproviderconnection.cpp.o.d -o src/core/CMakeFiles/qgis_core.dir/providers/ogr/qgsogrproviderconnection.cpp.o -c /tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/ogr/qgsogrproviderconnection.cpp
/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/ogr/qgsogrproviderconnection.cpp: In member function 'void QgsOgrProviderConnection::setDefaultCapabilities()':
/tmp/work/geography/qgis/work/qgis-3.44.9/src/core/providers/ogr/qgsogrproviderconnection.cpp:422:42: error: invalid conversion from 'CSLConstList' {aka 'const char* const*'} to 'char**' [-fpermissive]
422 | char **driverMetadata = GDALGetMetadata( hDriver, nullptr );
| CSLConstList {aka const char* const*}
ninja: build stopped: subcommand failed.
*** Error code 1
Stop.
make[1]: stopped in /n0/gdt/pkgsrc-current/pkgsrc/geography/qgis
*** Error code 1
Stop.
make: stopped in /n0/gdt/pkgsrc-current/pkgsrc/geography/qgis
