[gdal-dev] RFC111 AI/LLM tool policy: proposal for a significant revision
Even Rouault
even.rouault at spatialys.com
Wed May 6 09:29:39 PDT 2026
based on the experience gained from the initial policy, I propose to
significantly revise it to drastically limit their use. See
https://github.com/OSGeo/gdal/pull/14500
Even
http://www.spatialys.com
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
