[gdal-dev] RFC111 AI/LLM tool policy: proposal for a significant revision
Chris Toney jctoney at gmail.com
Wed May 6 10:27:43 PDT 2026
>What am I missing?
Possibly a lot. As a regular observer of the repository that's not my
impression at all. True a large number of PRs are by Even. Also true, so is
a substantial amount of review, especially (if not entirely), of
"difficult" PRs that take large review effort. Sustainability is a major
concern IMO.
Chris
On Wed, May 6, 2026, 11:14 AM Darafei "Komяpa" Praliaskouski via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hello,
> Is it possible to get a better overview of the actual negative impact
> you're seeing? Like, with actual examples of annoyances that happened.
> I tried my own research going through several pages of merged/closed PRs
> to get my impression on what went wrong but really most PRs are there by
> Even, with disappearingly small number of PRs from other people both by
> count and by volume, seemingly not enough to trigger such drastic policy
> flip.
> What am I missing?
> On Wed, May 6, 2026 at 8:29 PM Even Rouault via gdal-dev <
>> Hi,
>> based on the experience gained from the initial policy, I propose to
>> significantly revise it to drastically limit their use. See
>> https://github.com/OSGeo/gdal/pull/14500
>> Even
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> Highly recommend OxiGDAL if you want to live in the 21th century and cure
>> Bixonimania
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260506/3cb543a2/attachment.htm>
