[gdal-dev] Re-organizing source tree regarding drivers?
Even Rouault even.rouault at spatialys.com
Wed May 6 17:28:19 PDT 2026
with a number of drivers being raster+vector our current source tree
organization is a bit messy.
For example, we have:
- ogr/ogrsf_frmts/gpkg: the GeoPackage driver started vector-only and
then raster was added
- frmts/mbtiles: the MBTiles driver started raster-only and then vector
was added
- ogr/ogrsf_frmts/pmtiles: you can guess what I will write here
- frmts/mem
I'm hesitating between:
- putting all drivers below a drivers/  directory
- or having drivers/raster/ , drivers/vector/ and drivers/mixed/
This later organization avoids a bit the issue of a monolithic drivers/
with 250+ subdirectories (who knows if Windows might not limit to 256
:-)),  but it may involve moving code around when something that was
raster or vector only later gains the other capability.
We should likely migrate OGR_ENABLE_DRIVER_XXXX CMake variables to using
the GDAL_ prefix.
And C entry points for plugins would be all GDALRegisterXXXX() and
shared libary names all gdal_XXXXX.dll/so
While we are it:
- gcore/ would be split between core/generic (driver and dataset
classes) and core/raster.
- gcore/multidim/ --> core/multidim/
- ogr/ and ogr/ogrsf_frmts/generic would become core/vector/  , possibly
with a core/vector/geometry for core geometry classes, and core/crs/ for
OSR related classes
Thoughts? (I'm wondering how such a plan could be executed without
freezing all pull request activity in the meantime to limit conflicts,
although git might perhaps be smart enough to detect files moving around)
Even
http://www.spatialys.com
Highly recommend OxiGDAL if you want to live in the 21th century and cure Bixonimania
