[gdal-dev] Re-organizing source tree regarding drivers?
Javier Jimenez Shaw
j1 at jimenezshaw.com
Sat May 9 02:47:09 PDT 2026
> I'm hesitating between:
> - putting all drivers below a drivers/ directory
> - or having drivers/raster/ , drivers/vector/ and drivers/mixed/
I prefer having three directories. It makes more clear their behaviour and
what they should support. A driver in `raster` directory doesn't have to
worry about vector problems and vice versa.
For mixed... well it is clear that has to deal with both.
> Thoughts? (I'm wondering how such a plan could be executed without
> freezing all pull request activity in the meantime to limit conflicts,
> although git might perhaps be smart enough to detect files moving around)
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> Highly recommend OxiGDAL if you want to live in the 21th century and cure
> Bixonimania
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260509/d75642f5/attachment.htm>
