[gdal-dev] Support for Terrain-RGB
Even Rouault even.rouault at spatialys.com
Sat May 9 05:51:20 PDT 2026
Related ticket (regarding Terrarium) in
https://github.com/OSGeo/gdal/issues/14520 .  I'm not sure what the
solution is, but that proliferation of RGB formats to encode elevations
doesn't look pretty....
Le 05/01/2026 à 15:15, Lars Ahlzen via gdal-dev a écrit :
> Hi all,
> For Open/WebGL-based client side map rendering libraries, like
> MapLibre or Mapbox GL, Terrain-RGB [1] (original spec by MapBox I
> believe) seems to be the elevation encoding of choice.
> The encoding itself, meant for use with 8-bits per channel RGB raster
> formats such as PNG tiles, is straightforward:
>  elevation (in meters) = -10000 + 0.1 * (R * 65536 + G * 256 + B)
> As far as I know a separate tool is typically used for the encoding,
> such as rio-rgbify [2] from Mapbox. There's an example writeup of such
> workflow at [3]. Perhaps the same thing could also be achieved using
> the raster calculator (gdal_calc), but that seems far from trivial for
> most users.
> It looks like it would be relatively easy to add native support for
> this in GDAL, perhaps as another mode in gdaldem. Would it make sense
> if I gave that a try?
> - Lars
> [1] https://blog.mapbox.com/global-elevation-data-6689f1d0ba65
> [2] https://github.com/mapbox/rio-rgbify
> [3] https://github.com/syncpoint/terrain-rgb/blob/master/README.md
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
