[gdal-dev] Re-organizing source tree regarding drivers?
Daniel Baston
dbaston at gmail.com
Mon May 11 08:05:39 PDT 2026
While the current organization is definitely not what we'd start with, I'm
not sure the benefits or reorganization are worth making it harder to
follow the commit history. But I have no strong objection if others would
rather reorganize.
Dan
On Wed, May 6, 2026 at 8:28 PM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> with a number of drivers being raster+vector our current source tree
> organization is a bit messy.
> For example, we have:
> - ogr/ogrsf_frmts/gpkg: the GeoPackage driver started vector-only and
> then raster was added
> - frmts/mbtiles: the MBTiles driver started raster-only and then vector
> was added
> - ogr/ogrsf_frmts/pmtiles: you can guess what I will write here
> - frmts/mem
> I'm hesitating between:
> - putting all drivers below a drivers/ directory
> - or having drivers/raster/ , drivers/vector/ and drivers/mixed/
> This later organization avoids a bit the issue of a monolithic drivers/
> with 250+ subdirectories (who knows if Windows might not limit to 256
> :-)), but it may involve moving code around when something that was
> raster or vector only later gains the other capability.
> We should likely migrate OGR_ENABLE_DRIVER_XXXX CMake variables to using
> the GDAL_ prefix.
> And C entry points for plugins would be all GDALRegisterXXXX() and
> shared libary names all gdal_XXXXX.dll/so
> While we are it:
> - gcore/ would be split between core/generic (driver and dataset
> classes) and core/raster.
> - gcore/multidim/ --> core/multidim/
> - ogr/ and ogr/ogrsf_frmts/generic would become core/vector/ , possibly
> with a core/vector/geometry for core geometry classes, and core/crs/ for
> OSR related classes
> Thoughts? (I'm wondering how such a plan could be executed without
> freezing all pull request activity in the meantime to limit conflicts,
> although git might perhaps be smart enough to detect files moving around)
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> Highly recommend OxiGDAL if you want to live in the 21th century and cure
> Bixonimania
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260511/64645204/attachment-0001.htm>
