[gdal-dev] Re-organizing source tree regarding drivers?
Kurt Schwehr
schwehr at gmail.com
Mon May 11 09:53:14 PDT 2026
A reorg makes a lot of sense to me. Thanks for proposing it.
I would lean towards just having a `drivers/` directory.
A reorg will cause me a serious amount of pain because I work in the
google3 mono repo:
1) I use copybara to bring GDAL into google3 and build with a custom
bazel setup.
2) There are > 400 files spread across many teams that will need headers
changed.
But, that's my problem and shouldn't influence the decision.
On Wed, May 6, 2026 at 5:28 PM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> with a number of drivers being raster+vector our current source tree
> organization is a bit messy.
> For example, we have:
> - ogr/ogrsf_frmts/gpkg: the GeoPackage driver started vector-only and
> then raster was added
> - frmts/mbtiles: the MBTiles driver started raster-only and then vector
> was added
> - ogr/ogrsf_frmts/pmtiles: you can guess what I will write here
> - frmts/mem
> I'm hesitating between:
> - putting all drivers below a drivers/ directory
> - or having drivers/raster/ , drivers/vector/ and drivers/mixed/
> This later organization avoids a bit the issue of a monolithic drivers/
> with 250+ subdirectories (who knows if Windows might not limit to 256
> :-)), but it may involve moving code around when something that was
> raster or vector only later gains the other capability.
> We should likely migrate OGR_ENABLE_DRIVER_XXXX CMake variables to using
> the GDAL_ prefix.
> And C entry points for plugins would be all GDALRegisterXXXX() and
> shared libary names all gdal_XXXXX.dll/so
> While we are it:
> - gcore/ would be split between core/generic (driver and dataset
> classes) and core/raster.
> - gcore/multidim/ --> core/multidim/
> - ogr/ and ogr/ogrsf_frmts/generic would become core/vector/ , possibly
> with a core/vector/geometry for core geometry classes, and core/crs/ for
> OSR related classes
> Thoughts? (I'm wondering how such a plan could be executed without
> freezing all pull request activity in the meantime to limit conflicts,
> although git might perhaps be smart enough to detect files moving around)
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> Highly recommend OxiGDAL if you want to live in the 21th century and cure
> Bixonimania
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260511/64616c3a/attachment.htm>
