[gdal-dev] OGRLayer::WriteArrowBatch() and CreateFeature() mutually exclusive in the same session
Chris Toney jctoney at gmail.com
Mon May 11 14:39:56 PDT 2026
Thanks Even, that helps a lot.
Chris
On Mon, May 11, 2026, 2:50 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Chris,
> > I'm trying to understand implications of OGRLayer::WriteArrowBatch():
> >> This method and CreateFeature() are mutually exclusive in the same
> session.
> > The context is binding code where the user could potentially call
> > either of these methods at any point during the session.
> > Does "session" refer to the layer or dataset instance, or the GDAL
> > session itself?
> Dataset and layer instances
> > In tests with GPKG, using WriteArrowBatch() followed by
> > CreateFeature() worked and didn't cause any obvious problems.
> yes, because for that driver (actually all drivers except
> Parquet&Arrow), WriteArrowBatch() results in CreateFeature() behind the
> hood. But you'd likely hit issues on Parquet or Arrow datasets, for
> which implementation limitations lead to the general restriction.  And
> as we have nothing in the test suite that checks that mixing
> WriteArrowBatch() & CreateFeature() works even for code where it is OK
> currently, you could be exposed to potential regressions if the
> implementation changed in the future.
> >   Should
> > binding code guard against this in general?
> I'd say up to you. The SWIG bindings don't for example.
> > Similarly, CreateFieldFromArrowSchema() and CreateField() are mutually
> > exclusive in the same session. Is there any issue with using
> > CreateField() and WriteArrowBatch() in the same session?
> Same as above w.r.t Arrow/Parquet driver. The feature writing logic
> between the Arrow and per-feature strategies takes different code paths.
> I don't say reconciling them would be impossible, but clearly an
> implementation complication as I didn't see the point in supporting
> mixed workflows.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260511/a7f257eb/attachment.htm>
