[gdal-dev] RFC111 AI/LLM tool policy: proposal for a significant revision
Daniel Baston dbaston at gmail.com
Wed May 13 08:33:37 PDT 2026
> Just allow to put any PR into this mode, maybe via a tag or comment, and
don't look at it until there are some reveiws and their results are fixed.
Who will perform these reviews? When I review a pull request (not as often
as I should), I am trying to accomplish two things: (a) make sure that the
code is of good quality and does something useful, so that the project is
improved by its inclusion, and (b) help train a newer contributor who may
one day become a maintainer. Of these, (b) is by far the most important to
me, but if I review a vibe-coded pull request I feel like I am at best
accomplishing (a).
Dan
On Wed, May 13, 2026 at 10:31 AM Darafei "Komяpa" Praliaskouski via
gdal-dev <gdal-dev at lists.osgeo.org> wrote:
> Hi,
> Would love to share my perspective of someone who vibe codes. This email
> is fully organic produced.
> I feel like this second change is over-reaction, and the actual issue can
> be re-traced and fixed under existing policy.
> I have not brought AI/LLM pull requests to GDAL yet, but I have done that
> in other projects, lately on a larger scale. It has been a huge help for
> me: previously, I was annoyed at many issues in the software, but lacked
> applied skill to fix them across the diverse stack. In the case of PostGIS
> I was so annoyed that I had to learn C to fix stuff, and ended up on PSC,
> because many people were annoyed, but not many had the luxury to learn C. I
> wish I never had to learn C.
> Now, in the last couple weeks, I managed to fix build cache issues in
> ESPHome, fix build issues in the wifi7 driver of my new card, fix a cpu
> hotspot in htop, fix a metadata evacuation issue in bcachefs, update lora
> mesh simulator to validate my new assumptions on how to improve stability
> and get one negative and one positive result, configured redundant
> multi-isp network, fix all open tickets in h3-pg, and convert an android
> projector with calibration camera into a cat toy that plays with the actual
> cat.
> Previously this volume of changes would take years, and probably my cat
> will get unattended in the list. All this improved my quality of life too.
> Latest PostGIS day had a lot of examples of people using AI/LLM around
> GIS. It's early years still so there aren't many road rules yet so people
> still bump into each other, but I believe like git solved this for humans
> there will come some better solutions and traditions in the future.
> LLMs are also very steerable nowadays. Dropping AGENTS.md into project
> root and asking to test it [in which conditions] and to write in existing /
> desired style when coming PRs are doing same mistakes over is really
> changing what they do. Like, "read AI contributing policy in there: ..." so
> LLMs know what to aim for.
> I went so far as created a service that profiles hangs and crashes in the
> background and tries to stitch together an upstream patch:
> https://fixer.maumap.com/
> While walking this path, I met a different attitude from maintainers:
>  - The true "patches welcome": people give actionable feedback and merge
> stuff. When they're overloaded, they just reply that they are and pick up
> later, when they're free.
>  - "Fuck AI" - I had software crashed on my computer, got stacktraces,
> produced a patch, and got some "it can never happen, fuck your AI
> hallucination". Often it is rather bystanders than actual maintainers.
> After some discussion it usually got merged.
>  - "We know better" - a fun thing from OpenAI itself. They don't accept
> vibe coded patches (actually any patches) because their position is "we
> vibe code better and also can fix closed source servers instead, just give
> us prompts as tickets".
>  - "Peer review first" - especially popular in LLM-related projects.
> Patches just hang in there. Some people (or their AIs) pick them up, check,
> apply locally, run for a day or two, check if fix/feature is working and
> post a "we like this, here's evidences:" on a PR. Maintainers just ignore
> PRs until they're comfortable with what's in them.
>  - "We're not in git[hub] and don't accept PRs there" - annoying one.
> Sending patches over email seems very archaic, expecially when you need to
> first subscribe somewhere, can't reply to a thread that was there before
> you joined, and so on. Sometimes there's a github mirror but PRs are
> getting just straight rejected by bot, and you need to go serach where and
> how to register and then get replies in some weird way.
>  -Dead projects, that don't have anyone behind them anymore. I don't know
> how to handle that properly without saying "here's my fork, it at least
> works here too.
> I would love gdal to be a projct where I can still use AI/LLM to fix the
> issues that annoy me in the same way I do elsewhere. How about reworking
> this policy change from "no AI" to "need to solve maintainer capacity
> problem". I think the "Peer review first" policy from the above may
> actually adjust it better. Just allow to put any PR into this mode, maybe
> via a tag or comment, and don't look at it until there are some reveiws and
> their results are fixed. People who have coded something for the project
> are likely using it, can test, it should not be annoying for them as it's
> not them doing the local build nowadays, just their llm, and they also
> likely will be ok to spend some tokens for the automated review in addition
> to testing. After there are like five of them approving without complaints,
> maybe it's time to merge.
> It may also be a good idea to issue something like call for maintainers.
> It is okay for Even to not want to look at AI code, it should not be
> creating discomfort, and there are definitely people out there who are more
> okay with looking at AI code if it improves the FOSSGIS situation (hi!).
> Thanks,
> Darafei.
> On Wed, May 13, 2026 at 2:19 PM Even Rouault via gdal-dev <
>> Howard submitted a substantial update / counter-proposal to my initial
>> one. I've taking it, but with amendments re-introducing points of my
>> initial version. Please check
>> Le 12/05/2026 à 13:34, Even Rouault via gdal-dev a écrit :
>> > Any further comments before submitting to vote?
>> > Le 06/05/2026 à 18:29, Even Rouault via gdal-dev a écrit :
>> >> Hi,
>> >> based on the experience gained from the initial policy, I propose to
>> >> significantly revise it to drastically limit their use. See
>> >> https://github.com/OSGeo/gdal/pull/14500
>> >> Even
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260513/8edf5156/attachment-0001.htm>
