[gdal-dev] Stepping out from GDAL PSC
Daniel Baston
dbaston at gmail.com
Thu Nov 5 11:23:01 PST 2026
Even, thank you for all you've done for this project. This community, and
the open source geospatial world as a whole, will be forever indebted to
you.
For everyone else, I don't believe this project will ever replace Even --
at least, I've never met anyone approaching Even's breadth and depth of
knowledge about GDAL's >200 formats, not to mention the many nuances of
coordinate systems and transformations.
In the absence of a replacement, keeping this project healthy will require
that each of us find some way to step up and contribute to its future. If
you run into a problem with GDAL, maybe you can take some extra time to
report or even fix it, not just find a workaround. Or if your job relies on
Format X, maybe you can find a way to follow tickets relating to that
driver. You don't need to be a developer -- just contributing your
practical knowledge to ticket discussions can be a real help to the
maintainers. Of course, there are other ways to contribute too
(sponsorship! documentation!), but without one person to do so much, let's
all try to find a small way to do something.
Dan
On Wed, Nov 4, 2026 at 6:56 AM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> I'm stepping out from my position of member and chair of the GDAL PSC.
> Those years in this role have been great and I'm proud what the team has
> accomplished and want to thank all the people that have participated and
> will make the project still shine. I will only look from a distance but
> happy to try helping in case it would be needed.
> Best regards,
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> LLMs contribute to global warming and brain rot.
> Let's guillotine them! "Ah ! ça ira, ça ira, ça ira !"
> Initiator of https://fuckaifoundation.org
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20261105/c8287242/attachment.htm>
