[gdal-dev] Stepping out from GDAL PSC
Norman Barker norman.barker at gmail.com
Thu Nov 5 12:33:34 PST 2026
Even,
I have worked with you on many occasions and you have always been a
pleasure to work with. Working with you has improved me as an engineer and
I have appreciated all of the feedback you have given me in email, PRs and
in person as it has always been thoughtful.
>From a project perspective, you have been one of the driving forces behind
GDAL for many years and have spearheaded some of the big changes, the move
to CMAKE for example and then also the move to make format drivers as
plugins are two of many examples. These are things I now take for granted
without remembering how painful building and installing GDAL was on
different platforms, including Windows, before CMAKE was available and
adopted by GDAL. The work on GDAL multi-dimensional was also very well
thought out and is easy to use.
I hope whatever you do next is just as successful.
Norman
On Thu, Nov 5, 2026 at 2:14 PM Andrew C Aitchison via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> On Wed, 4 Nov 2026, Even Rouault via gdal-dev wrote:
> > Hi,
> > I'm stepping out from my position of member and chair of the GDAL PSC.
> Those
> > years in this role have been great and I'm proud what the team has
> > accomplished and want to thank all the people that have participated and
> will
> > make the project still shine. I will only look from a distance but happy
> to
> > try helping in case it would be needed.
> In the announcement here Even has only said that he is stepping down
> from the Project Steering Committee, but from what others have said,
> I gather that Even is no longer going to be working full time on GDAL.
> Can someone confirm this ?
> Thanks,
> Andrew C. Aitchison                      Kendal, UK
>                     andrew at aitchison.me.uk
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20261105/ec817301/attachment.htm>
