[gdal-dev] xvrt (Python): write multidimensional VRT
Michael Sumner
mdsumner at gmail.com
Sat Nov 7 11:56:38 PST 2026
Hi, xvrt is on pypi (it models mdim VRT but doesn't depend on GDAL to
install or generate VRT xml).
https://pypi.org/project/xvrt/
I use it to generate multidimensional VRT datasets from a limited range
of raster inputs (think time series of GeoTIFF/COG, my use case includes
byte ref harvesting ala GetRawBlockInfo()/Icechunk/Virtualizarr but mdim
VRT has immense value on its own).
GDAL can currently work with GTiff in MDIM VRT but not generate it from
GTiff (I'd like to contribute to change that and make this a pipeline algo
in GDAL itself). `gdal mdim mosaic` is the high powered general case of
which xvrt is a mere special and simple case.
xvrt lives at https://github.com/hypertidy/xvrt
Cheers, Mike
Michael Sumner
Research Software Engineer
Australian Antarctic Division
Hobart, Australia
0438489030
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20261108/24e2d545/attachment.htm>
