[gdal-dev] Maintainers and PSC: please reject bulk PRs from fake GitHub personas, correct or not
Daniel Baston dbaston at gmail.com
Thu Nov 12 04:12:28 PST 2026
Sean,
I've had several such PRs lately on GEOS [1], so it's a good example. All
of them identified real issues. Some of the fixes were fine to apply as-is.
In other cases I kept the tests from the PR and wrote my own fix. Since I
doubted that human was strongly invested in them, I didn't worry about
back-and-forth, I just took what I wanted and moved on. Nothing rose to the
scale where copyright would have been a concern, and in any case an AI
policy like GDAL's would block such contributions. Of course I would have
preferred to see fixes from a motivated human contributor who was deeply
invested in the geospatial field, but that's not what I got.
The way I read your proposal, you're suggesting for each pull request I
first try to judge the submitter's motives. Are they doing some sort of
karma farming? If so, I must then either:
(a) close the PR and forget it, even if I think it fixes a real issue
(b) close the PR and write a fix myself
Because I believe (a) would harm GDAL's credibility and (b) only increases
the burden on the project's maintainers, I would not be supportive of such
a policy.
Dan
[1] https://github.com/libgeos/geos/pulls?q=is%3Apr+author%3Aalepacheco
On Wed, Nov 11, 2026 at 1:54 PM Sean Gillies via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hello,
> It's been a while since I've posted here. I hope you're doing well in a
> weird time.
> Today I saw an adjacent FOSS4G project merge a PR by
> https://github.com/KennyMcSimpson. I encourage you to browse to the
> profile of this entirely phony person and notice that "they" made 122 PRs
> in 96 projects in one October day.
> https://github.com/Tyagiquamar is a contributor to GEOS. 190 PRs to 92
> projects in one November day.
> This pattern will be coming to GDAL soon. Please reject PRs from such
> sources. Accepting makes a mockery of open source, rewards bad actors,
> erodes trust in a project, and I believe it accelerates the downfall of
> GDAL.
> I'm not saying don't use AI yourself. I'm only saying don't let obviously
> fake personas commit to GDAL. It would be better for GDAL project
> maintainers to do this kind of thing themselves if they feel it is
> important and necessary.
> I'd love to see a sign that the PSC recognizes that this is a problem in
> the FOSS4G and implore you to adopt a policy against accepting these fake
> contributions. They're not hard to identify, it only takes a click or two
> and a little scrolling.
> Yours,
> Sean Gillies
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20261112/a4f00ac7/attachment-0001.htm>
